Finally went to DYNO!! Untuned though. PIC!!!!
Looking at the boost gauge I Was boosting about 8psi. I have a 3.125 pulley. 6:1 disc, Cattman Y pipe, 1 Step colder plugs and Universal Muffler. Still on Stock B pipe and Stock cat. Hopefuly will be able to get it tuned next week with better numbers.
Comments?
Comments?
Originally Posted by 96shogunmax
but he got a spinning wheel there......
I have a wheel there too.. it doesnt spin. Gota put a motor on it. SHould have BORROWED it from sadlar :-p
I'm curious to see your car tuned
I'm only NA, but I'm having a tough time deciding whether or not to go with the G-Force/Technosquare ECU or to just use the piggy-back A'pex S-AFC II. I already bought the A'pex and Eric at XS Engineering expects to see at least 12 wHP gained, but at least the G-Force is a sure gain. If your numbers are good, I just might stick with the S-AFC and get it dyno-tuned.
Originally Posted by 2k2wannabe
what happened on that 165.9 run?
Originally Posted by bags533
good numbers oss.. let aurthur do his thing and tune it.. and if you get a better exhaust you'll see more HP.. but it will be louder
Just need to tune it and I should be set. May be pick up MEVI somewhere down the road never know.
Originally Posted by SprintMax
thats not bad for an SC Auto 4th Gen
Its DAMN GOOD for my Custom 5Speed AutoMaGiC :-D
Isn't 8psi really low for a 3.125" pully? Are you bleeding off boost?
Originally Posted by ejj
You've got a V2, right?
It is a V2 and I did think i should hit 10 atleast. I need to check the gauge I guess or may be run and keep an eye on the gauge.
Originally Posted by MAXIN
I thought those apexi El's have peak/warning/memory....
My Boost gauge is Mechanical. Kinda regret getting mechanical though. Should have spent the extra $$s.
Originally Posted by Stephen Max
What did your AFR look like? I would think a 6:1 FMU with a 3.125" pulley would be a little lean. Maybe not since you don't have a MEVI.
Once I go get the tuning done next week I will get back toyou with AFR numbers.
Oss.. next time leaving in Drive .. and don't click the Over Drive Button
Its funny that when it is in N it drives DAMN good but everytime I shift to D it wont move
Apr 16, 2020 05:15 AM
I see, please excuse my ignorance.
