Couple of Fuel Pressure Regulator questions?
Sup Folks I know its been a while since I posted. I've been getting some drift events going down here in Houston. www.dailydrifter.com
If you're in the area come watch the next one they're a blast.
Ok now to the Max. I may take the record on turbo projects, huh?
So some of you may remember me and the Haltech didn't get along.
So I went ahead and went the route most have and got the SAFC2 (for $250) and I already have a fuel reg.
First off, with the Haltech all I worried about was making sure I had higher fuel pressure. So what I did was connect the hose from the stock FPR to the High FPR. then back to the tank.
So it went tank->filter->fuel rail-> stock FPR -> high FPR->back to tank.
My reasoning was if the pressure got too high for the stock FPR it would open and shoot it to the high FPR where I would control how much pressure I really wanted.
But since I want to lower the fuel pressure now because I have a stock Ecu with a walbro pump and z inj. should I remove the stock FPR to make sure I can lower the pressure with the High FPR?
Now my second question. If I lower the pressure with the adjustable FPR
how will I get the higher fuel pressure I need when I get into boost.
I'm not a newbie when it somes to working on cars but I don't know much about how the adjustable FPR's work.
Third question- What's the stock pressure and how much lower should I go when at idle?
I guess I didn't really deal with these issues before because I had a tuner and was using Haltech. I'd like to know what's going on a tad more now.
Sorry so long.
Sorry so long.
Hmm ok I'll have to find out if what I have is a FPR or FMU the above pic shows a vaccum so it may use vaccum to tell. I'll check it out today.
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
doobadoo
Aug 15, 2015 06:43 PM
Superbform
Aug 11, 2015 08:10 PM
