Installed new plugs, car won't run, help?
Damn, installed new NGK plugs, gapped to .043, took 'em in and out twice to make sure. Idles rough, won't run when cold, shifts like crap, no wires loose, nothing out of place. Anybody have any suggestions? Sounds like a vaccum leak but I can't find anything.
Plugs were PFRG5-11, same as came out. All ignition ciols back in the same spot and hooked up. Also did throttle body cleaning at the same time so yes I had the air box out, unpluged MAS and reconnected, took off the three vaccum lines from the air box and reinstalled. Did all this twice in 2 days.
Is it possible you hooked up the coil wiring incorrectly? This would cause the engine to run rough or not at all due to the cylinders firing out of order.
Has the ECU thrown a code?
How did you do bank 1 without taking more apart, i.e. the intake manifold?
Bad plug perhaps?
Put the old ones back in and see how it runs.
Did you have to move anything on the rear bank to gain access to the coils? On our 4th gens we need to move the idle air control valve. Maybe something is disconnected back there.
Is your check engine light on?
Put the old ones back in and see how it runs.Did you have to move anything on the rear bank to gain access to the coils? On our 4th gens we need to move the idle air control valve. Maybe something is disconnected back there.
Originally Posted by njmaxseltd
Bad plug perhaps?
Originally Posted by BigDogJonx
Damn who you know nauman that hooked it up backwards? That plug takes alot of pressure to jam it in the wrong way.
Dixit
Dixit
it was on a 4th gen... but yeah, it would be hard to do on the 5th gen... but who knows?
was worth a guess
Hahaha, damn..... Thats bad. BTW you aint reply to my last email I sent a week ago when you asked me some questions.
Dixit
Dixit
been crazy busy at work... It's in my inbox... I'll reply to it
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
Team STILLEN
Aug 10, 2015 04:29 PM
