What is a caliper bracket?
Old Oct 6, 2003 | 05:28 PM
MikeS's Avatar
Is what Autozone calls a caliper bracket the same thing as the torque member or does the torque member come with a reman caliper? I ask because I just need a torque member and noticed that Autozone sells something called a caliper bracket but it is a order only item.
Thanks.
Old Oct 6, 2003 | 05:44 PM
Chunger's Avatar
My other car is a Hybrid
Torque member = caliper bracket...
A remanufactered/rebuilt caliper usually does not come with the bracket.
Try the junkyard for the bracket... it's probably cheaper.
Old Oct 6, 2003 | 05:48 PM
njmaxseltd's Avatar
Why in the world do you need that part? What happened to the old bracket?
Old Oct 6, 2003 | 05:50 PM
MikeS's Avatar
I hope so it's only 32.99 from them but now I'm wondering if the bracket is what the torque member bolts to?
Old Oct 6, 2003 | 05:53 PM
Chunger's Avatar
Old Oct 6, 2003 | 05:58 PM
99maxx-on19's's Avatar
i'm going to buy new calipers tomorrow am i getting any brackets?? kinda new a brake stuff
Old Oct 6, 2003 | 06:00 PM
Chunger's Avatar
You can always ask to be sure....
Old Oct 6, 2003 | 06:26 PM
MikeS's Avatar
You are sure that #1 is the caliper and #2 is the caliper bracket (torque member), if you look behind the rotor at the piece that the torque member attaches to, what is that called?
Old Oct 6, 2003 | 06:29 PM
Chunger's Avatar
[image]http://img.villagephotos.com/p/2002-11/67596/maxima1.JPG[/image]
You are cure that #1 is the caliper and #2 is the caliper bracket (torque member), if you look behind the rotor at the piece that the torque member attaches to, what is that called?
Spindle?
Old Oct 6, 2003 | 06:30 PM
MikeS's Avatar
Looks much different with dust shield off! Thanks a bunch!
Old Oct 7, 2003 | 11:12 AM
maxcross's Avatar
I had to p/u a bracket when I replaced the rotors cause I snapped one of the bolts and I was too lazy to tap it out. I do remember having to buy the whole caliper assembly though.
Old Oct 7, 2003 | 05:08 PM
MikeS's Avatar
Thanks again I bought just the caliper bracket and it is the torque member.
Old Oct 7, 2003 | 08:39 PM
rguida's Avatar
I need a new caliper bracket because one of the bolts in the old one is frozen, making for VERY uneven pad wear.....nice find...my dealer wanted 200 for an entire new caliper to get the bracket (aftermarket mind you)
Old Oct 8, 2003 | 12:20 AM
Chunger's Avatar
Glad it worked out for you.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Calabar
Oct 5, 2015 09:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
