Ecu Screw for 99 Maximas, WHY?!?!
Old Oct 8, 2003 | 09:06 AM
Ninos_Maxima's Avatar
be the change u want2C
Why is the ECU screw for 99 Maxima so deep inside the whole!!! I can never get it right, it take like half an hour to get it!
Old Oct 8, 2003 | 09:12 AM
dpassino's Avatar
are you sure you even have the screw? i dont even see the screw. I am so confused. all i see it a white plastic looking thing (circular with grooves around the edges)
i have a 99 as well
Old Oct 8, 2003 | 09:20 AM
I do, but its so deep inside!!! its so annoying, Somone should make a 99 ECU screw mod, lolololol
Old Oct 8, 2003 | 10:50 AM
dpassino's Avatar
is it a flat head or philips head, and is it the regular size or ultra small?
Old Oct 8, 2003 | 10:52 AM
Jeff92se's Avatar
I'm needing a caw
Do you have the same problems in bed too?
Old Oct 8, 2003 | 10:53 AM
MrEous's Avatar
^ Jeff™
It's an ultra small phillips screwdriver...
...quit wiggin' out man. I don't have a problem finding the hole. *shrug*
maxNYC's Avatar
heh... just gotta laugh at some of the responses
Old Oct 8, 2003 | 11:00 AM
dpassino's Avatar
if i take it to autozone today will they get the code and clear it if i ask?
Old Oct 8, 2003 | 11:03 AM
ejj's Avatar
ejj
Yeah, 99 ECU screws are VERY different from other 4th gens. Go at it with your smallest phillips head screwdriver.
Old Oct 8, 2003 | 11:07 AM
drewm's Avatar
Even when I was an ECU screw virgin it only took me 10 seconds to hit it and screw it. Use a jewler's philips screwdriver and it's as easy as done.
Only in a thread like this could we ever use such suggestive comments.
Old Oct 8, 2003 | 08:33 PM
I thought it was a flat head screw? Well anyways thanx for the help, o and the flames too, lol
Old Oct 9, 2003 | 05:26 AM
ejj's Avatar
ejj
95-98's are flatheads. Its much easier to see and get to on them.
I've screwed a 96, 97 and a 99...I would know.
Old Oct 9, 2003 | 07:24 AM
MrEous's Avatar
^ Jeff™
Ewww...a 4, 6 & a 7 yr old? lol
Old Oct 9, 2003 | 07:39 AM
ejj's Avatar
ejj
What can I say, I like 'em young!
Old Oct 9, 2003 | 08:11 AM
JNCoRacer's Avatar
Just the tip.
You dirty, dirty man...hahaha.
Old Oct 9, 2003 | 11:01 AM
hakk97se's Avatar
Gotta get em before the hair does.
Old Oct 9, 2003 | 11:12 AM
MrEous's Avatar
^ Jeff™
Old Oct 9, 2003 | 11:52 AM
maxNYC's Avatar
jail bait!@@!!
Old Oct 9, 2003 | 11:55 AM
xHypex's Avatar
Maybe I'm just used to my '99, but I think it's much easier to get to. The screw turns easier and you can feel the end "stops" better. I think the '99s don't need to be turned as many degrees as the earlier flathead ECUs either.
-hype
Old Oct 9, 2003 | 12:03 PM
ejj's Avatar
ejj
I couldn't disagree more!
-hype
That's true. You had to turn a 95-98 a long way, but the 99's don't need nearly as much rotation.
Old Oct 9, 2003 | 12:07 PM
MrEous's Avatar
^ Jeff™
Well if the earlier models had a much smaller screw like the '99s then they wouldn't need to be turned as much.
I have -0- complaints with mine.
Superbform
Aug 11, 2015 08:10 PM
kirkhilles
Aug 8, 2015 10:53 AM
maximaham
Aug 7, 2015 01:11 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
