BROKEN Control Arm Bushing
Old Oct 8, 2003 | 07:57 PM
Venom181's Avatar
Ok! My Maxima is Slowly Eating itself away! I dropped it off one night at Tire Kingdom and found out there 7 point inspection was NICE!! About $2300 Nice... A little bit here and there... So I told them all I wanted was an Alignment and Oil change. WoW
Ok Next, I just wanted to Know if anyone knows if the Lower Control arm Bushings are replaceable. I dont want the whole control arm, just a Bushing in the Arms joint.
I found the Bushings on Car Parts $42, but I just wanted to know if its possible to change them or the part I found was for something else..
Thanks, any info would help!
Old Oct 8, 2003 | 08:01 PM
DanNY's Avatar
Ad·min·is·tra·tor
yup u can change them..just need a press to press them out.
bushings are available at the dealers.
Old Oct 8, 2003 | 09:12 PM
Matt93SE's Avatar
STFU n00b!
Little something you might want to consider.
http://forums.maxima.org/showthread.php?p=1597107
If you still insist on doing it yourself, I've posted a writeup at www.4dsc.com/articles
Old Oct 8, 2003 | 11:35 PM
anaximander's Avatar
I was ripped off a couple times like that in the past. ALWAYS get a second opinion if they say that your car needs a major repair. Three things can happen; a) it indeed does but you can fix it much cheaper at an independent shop, b) it does not and can be fixed otherwise, c) it is something else and is a minor problem. Some would argue that it could be d) there is no problem or is uncritical to be repaired and they just want your money.
Old Oct 9, 2003 | 08:51 AM
internetautomar's Avatar
mod or sell?
Use the bushings from an 88 max. and do a search.
Old Oct 9, 2003 | 01:11 PM
Jack.'s Avatar
Jees, my bushings are ripped, both outer cv boots are nearly missing and 1 of my spider boots is torn down the center. I noticed all of this while fixing my power steering.
That's going to be a lot of work. And yes the joints are perfectly fine, still packed with grease, I just have to fix it quick.
knight_yyz
Nov 1, 2015 01:34 PM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
