245/45/18 tires on I30??
18"by7.5" and 245/45/18 tires combination will fit '99 i30??
I got H&R springs and GR2 shocks which ready to install.
one more thing! ....What If I install the H&R lowering spings with stock 15" wheels and tires, any problems to drive around NYC? (hitting bumps, pot holes..etc)
I really wanna know....help me guys,
245/45/18 tire is kind of tall. most ppl use 245/40 on 18x8.5" wheels
Originally Posted by 97GLES
you need to know what the offset is.
off set is 40mm. this wheel is 2004 Maxima stock one.
you think drive with 15" wheels+lowering is fine??
Thanks anyway.
Originally Posted by I30tMikeD
That size tire will make your speedo off, it's the wrong diameter.
15" wheels + lowering is fine, won't look as good but it's fine.
Thanks for your reply.
then, what's the good tire size for 18" or 17" Nissan oem rims for my
i30??
Originally Posted by Arvinda Chetram
I30T, what do u mean by it will make your speedo off, the speed that shows up on the speedometer wont be correct?
No it won't. When you change the diameter of the tire you essentially change the gearing. Too small and your speedo will read fast, too tall and it will read slow.
so 225/45 R18, 245/45 R18, on something like a Infinti I30(96), would be affected in this way? is there any way to fix it?
Originally Posted by QBsFinestVQ
don't listen to the others...245/45 will be fine...but replacement tires are quite expensive in that size
it will make the speedo off, that is just a fact
