TIRE repair
Old Oct 10, 2003 | 11:58 AM
Maxima-2's Avatar
TIRE repair
Does anyone know of any fixes for a small gash/peeled back rubber in the sidewall of a 40 series tire? Thanks in adavance for any help!
Old Oct 10, 2003 | 01:31 PM
BigDogJonx's Avatar
Gashes in the sidewall are not fixable. Almost not one tire repair shop will touch it.
If its not leaking air I would not worry about it. If anything maybe put some tire repair sealant under the gas so the part does completely peel back.
Dixit
Old Oct 10, 2003 | 01:45 PM
nadir_s's Avatar
vicodin ... gift of life
it's illegal to fix a sidewall... looks like you'll have to replace it
Old Oct 11, 2003 | 02:37 AM
PhxBlue's Avatar
MK3 Supra and Focus ST
If it is just a slight cut it is only cosmetic. There is no way to fix that.
Old Oct 11, 2003 | 06:50 AM
Maxima-2's Avatar
thanks all thats what I figured. The rims are comming off in 2 weeks anyways in prep. for another fun Buffalo winter, I am just a bit concerned to drive on it with the amount of pressure I put my tires under!
Old Oct 12, 2003 | 07:26 PM
DJMaxGLE's Avatar
Could someone care to explain?
confused noob
Old Oct 13, 2003 | 12:29 AM
lightonthehill's Avatar
The 'fix' for the tread portion of a tire will not work on the sidewall.
The tread area of a tire is thick, with many plies, belts and around 11/32nds of tread (when new). A plug through a hole in the tread area has lots of 'surface' (due to thickness of the tire at this point) to cling to.
The sidewall, however, is much thinner than the tread area, with no belts, no tread, and few plies. Nothing for a plug to cling to.
Examine the gash carefully. If you can see the one or two plies usually found in the sidewall, and there has been cutting of these plies (to ANY extent), don't take a chance.
I realize this is not the news you were hoping for, but we need to keep as many MAXIMA.ORG posters alive as possible.
mkaresh
Mar 12, 2018 06:48 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Garrettz459
Sep 28, 2015 02:50 PM
