Owners with Vortech Super FMU
Old Oct 10, 2003 | 08:46 PM
Morfeus17's Avatar
Almost done with the turbo setup. I should have it out of the shop by Saturday evening.
Just wanted some info on the Vortech Super FMU. I'm planning to run 5psi on stock everything. At 5psi, what fuel pressure should I expect from this system from idle to WOT??? I'm not sure about disc sizes, the thing is adjustable. Numbers would be good so I can gauge myself with the fuel pressure indicator.
Also, should I run the SFMU stand-alone or with the existing FPR???
Old Oct 10, 2003 | 08:57 PM
Shadow's Avatar
SFMU should replace your factory FPR. It's supposed to be the FPR and FMU all rolled up into 1 package.
For reference, thebigsadler's car hit 65 psi fuel pressure at full boost (5psi). At first, it was at 80 psi at full boost, but on the dyno this showed it was running way rich. Taking it down to 65 psi brought the A/F to a nice 12:1 which is really where it should be.
But different size turbos flow different amounts of air at the same psi. Do you also have an EGT gauge? That will really let you know if you're rich or lean. The best way to do this is to get it on the dyno, but I know a lot of people aren't near dyno facilities.
Old Oct 10, 2003 | 09:46 PM
Morfeus17's Avatar
So between 60-65psi depending on turbo is the mark... Ok thats good and I do have an EGT gauge. I will watch temp. By the way, whats the ideal temp. If I position the probe right after the junction point where the two banks meet?? Should it be around 800 to 1000 F???
As far as dyno, thats a tuffy... I'm no where close to one.. I would need to rely on what I have at my disposal.
Old Oct 11, 2003 | 11:52 AM
BigDogJonx's Avatar
Honestly everycar is slightly different, you cant just say 60-65psi FP on 5psi. Because on my car at 43psi FP I was 12.5:1 a/f flat lined on 5psi boost. Too many variables. You need to take it to a dyno.
Dixit
Old Oct 11, 2003 | 07:40 PM
Morfeus17's Avatar
I see. Its pretty hard to dyno in the NY area. But thanks...
Dixit
Old Oct 25, 2003 | 10:59 PM
Chunger's Avatar
My other car is a Hybrid
How many members here are actually using a VORTECH Super FMU?
I think my SARD FPR has already started taking a dump after only a few months of use...
Old Oct 26, 2003 | 07:14 AM
JDM4LIFE's Avatar
how do you like your vortech sfmu? an fmu is basically the last piece i'm missing from my turbo setup, so i'm doing some comparison shopping... how much did you pay?
Old Oct 26, 2003 | 07:20 PM
Morfeus17's Avatar
My Vortech SFMU costs $250. I' still have not yet installed it. I'll let you know the results.
doctorpullit
Oct 28, 2019 10:58 PM
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
bernyp
Oct 2, 2015 10:10 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
