My first problem ever @ 31,800mi - Vibration - HELP
Old Oct 12, 2003 | 02:41 PM
02MaXiMa_GLE's Avatar
This is my first ever problem with my Max. The front end comes under severe vibration around 45mph and especially around 60-70mph. I thought the wheels might need balancing - never had it done before.
So today I had all 4-wheels balanced @ Firestone shop for $50. Well I still have the same problem! Is there something else I should be looking at, or did these jerks NOT do their job right?...
Also, I need to travel 150mi round-trip to NYC tonight & I think I may have to cancel it due to hazard of having my front end fall apart...
What do you guys think could be causing this? Any ideas? I plan on taking it to the dealer... but Sunday serviceshops are very "easy" to find.
G
Old Oct 12, 2003 | 04:48 PM
Nyc2kMax's Avatar
might be rotors if i was you i'll check to see if they are wraped.
Old Oct 12, 2003 | 04:53 PM
mad2kmax's Avatar
does it happen when you are braking or all the time? Like nyc2kmax said, if its when you are braking, its probably your rotors. stock maxima rotors are terrible and tend to go bad rather quickly.
Old Oct 12, 2003 | 04:59 PM
Gsilk's Avatar
Reported
I had the same problem on friday night with my 2000 gle. it was my front rotors. they (local nissan dealership) resurfaced them for a total cost of $90
Old Oct 12, 2003 | 05:31 PM
No no... not when I'm braking... when I'm riding normally at those speeds.
Is that the same problem you guys are talking about, or was it when you were braking only?
Thanks,
G
Old Oct 12, 2003 | 05:51 PM
Gsilk's Avatar
Reported
Thanks,
G
for me is was very bad when braking but i noticed it also when driving. the fastest i went was around 50 and i could feel it then. it wasnt the road
Old Oct 12, 2003 | 06:55 PM
slizan99's Avatar
G
what kind of tires do you have? i'm betting its the stock potenzas. find a tire shop that can measure road force variation in a tire. your tires could be the issue.
Old Oct 12, 2003 | 07:26 PM
filtor1's Avatar
G
I had the same issue. Turned out to be my wheel barrings. It got so bad that Nissan had to replace the entire hub assembly due to the vibration. Your still under warranty. Take it in. Good luck!
Old Oct 12, 2003 | 09:00 PM
handsofstone's Avatar
i'm having the same problem, i hope it's just the rotor's. if its the wheel bearings, how much do they cost to replace?
Old Oct 12, 2003 | 10:18 PM
WILLSE's Avatar
might be motor mounts.
will
Old Oct 13, 2003 | 12:19 AM
if it was the motor mounts, the car would shake really bad when not moving.
Old Oct 13, 2003 | 01:08 AM
PHATMAN5050's Avatar
I'm having the same problem but only when I accelerate, the second I let off the gas I'm smooth sailing. I've heard CV Joint, coil, tires, alignment. I'm getting my alignment done on tuesday, if that doesn't help, I'm ripping the engine bay and suspension apart until i find the culprit! haha
Old Oct 13, 2003 | 01:11 AM
GreekMaxima's Avatar
my car and steering wheel vibrate when i press my brake pedal... i need front rotors... my dealer wants $140 for clear them and i was like no way... i'll get a new rotors like powerslot with $20-$30 extra... fu*k that yo...
Old Oct 13, 2003 | 03:32 AM
steelymatt's Avatar
G
You were correct in that your wheels need to be balanced. Not a big deal, it's just hard to find someone to do the job right. I went to Goodyear and I didn't have much luck with them. Go to an Infiniti dealership. At least you'll know they're probably doing things correctly. Also, make sure your left and right tires are equal pressure. If after this, they're still vibrating, then you have something wrong with a tire or rim.
Old Oct 13, 2003 | 03:51 AM
Triple8Sol's Avatar
I miss the .org!
I would say your wheels were out of balance, but since you had that done...maybe you have a bent rim? I bet most people have a rim that isn't straight/true, but don't know it b/c it's not blatantly visible.
Old Oct 13, 2003 | 07:36 AM
Atl_2K_GLE's Avatar
Well Said. Just because you have HAD your wheels balanced, doesn't mean your wheels ARE balanced. I go to Good Year. Often have to take it back 2-3 times before they get it right, with SPECIAL instructions. REMOVE old weight tape from the wheels. HAND TORQUE lug nuts. I like good year as I have grown to know the guys and they are RIGHT across the street from my office. VERY convenient.
If your car is vibrating heavily upon deceleration, have rotors turned (very common amongst us Max owners). I had this done and the car now rides good as new, even makes balancing easier IMO.
If it's vibrating upon acceleration...Check tires thoroughly (rubber could be separating), check motor mounts, joints, bearings.
Hope it helps.
Old Oct 13, 2003 | 08:56 AM
filtor1's Avatar
Part # DAT 40210-2Y000... Bearing assy-fr $41.06 ea.
Courtesy replaced mine for no charge. I purchased the 100,000 mile extended warranty. Hope that it isn't the brakes if your anywhere close to 30,000. I was at 34,000 and Nissan said they wouldn't cover it. I found a local guy that turned all four and put EBC greens on the front for $69.00. Now 13,000 more miles and the judder is back. I think we will all be fighting with the rotors until we go aftermarket. Good luck!
Old Oct 13, 2003 | 04:26 PM
Damn. Thanks everyone. I will check in with the dealership this week. I suspect it was "NOT" balanced properly... bastards! If Nissan charges me for balancing and that solves the problem, then I will get the other guys to refund my $$$ 100%.
G
Old Oct 13, 2003 | 04:41 PM
There is an infiniti dealership down the street form my house. i think i will have them balance the wheels for me. i hope that's it.i am waiting for the brakes to get bad before i get some bigger rotors and some EBC's.
Old Oct 31, 2003 | 07:37 AM
williaa's Avatar
I got this problem, too(between 60&70 and 90-100). I had my new tire rebalanced and it quit between 90-100 but continued between 60&70.
Old Oct 31, 2003 | 07:48 AM
Galo's Avatar
Maxima Pilot
Just FYI....it took me three tries with a Hunter 9700 Road Force analyzer to get my balance right....definitely try a Road Force.
Old Oct 31, 2003 | 09:02 PM
DAMN, this thread is BACK from the DEAD?... muahahaha...
It's under warranty, right?... Take it to the dealer. They replaced my HUB, AXLE, SPINDLE... all under warranty.
G
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
