VE injectors in VG??
alright guys here's my problem i have a VG30ET and i am using my stock N/A VG injectors. So i was wondering if i could use the VE injectors?? Also do u think the stock ECU can handle the VE injectors? thanks guys in advance.
Miguel
Miguel
it looks like you might be able to use the ve injectors. i can only tell by comparing connector colors so i'm not 100% positive. you will need some sort of way to control them since they are bigger. apexi s-afc, greddy emanage, etc. should work. the best way would be to get your ecu reprogrammed.
you have any pictures of your setup?
Originally Posted by MrGone
VE's are side feed, VG's are top feed.
now supply pics so I dont feel bad for not saying search
covered this with pics a little while back
yeah, vg's are side feed as well. the n/a vg injectors definately won't supply enough fuel for the turbo engine. they are only 180cc so you will definately need something bigger a long with a better fuel map.
Thanks for the info guys so i guess i will try the VE injectors and see how it goes. I would have attached some pics but my computer crashed so i will take some new ones ASAP so u guys can see how i set it up. Sorry about not searching but it wasn't working when i posted. thanks again
Miguel
Miguel
I'm thinking that the harness connectors may be different. Thought I read that somewhere on here, that the alignment "keys" are in different places. Guess if that's true you could file them off or something..
the 7/92 - 94 VG has the same exact connector as the VE though just a different color
jmlee44
Oct 2, 2022 02:13 PM
