Can NE1 tell me if Tiens are stiffer than Eibachs? (did a search)
Old Oct 14, 2003 | 08:34 AM
bwalsh's Avatar
Can NE1 tell me if Teins are stiffer than Eibachs? (did a search)
Old Oct 14, 2003 | 08:50 AM
Igor911's Avatar
they are lower, so yes.
Old Oct 14, 2003 | 08:54 AM
NT2SHBBY
teins might be lower out of the box (yours (cut) are def lower than teins), but from what I hear eibach pro-kits are the stiffest compared to coilovers
Old Oct 14, 2003 | 08:57 AM
Igor911's Avatar
yes mine are cut but they are not lower than tiens
Old Oct 14, 2003 | 11:26 AM
UMD_MaxSE's Avatar
Got Bent?
No.
lower does not imply stiffer.
Old Oct 14, 2003 | 11:31 AM
02'maxed-out's Avatar
to be totally honest on my opinion...
i rode in a car with Eibachs...... a bit stiff...
my car wit Teins...a little stiff...but comfortable than Eibachs...
Old Oct 14, 2003 | 11:33 AM
MaxSE03's Avatar
Tein spring rates are: 201lbs front and 269 lbs rear.
Let me do some search and see if i can find the Eibach rates.
Old Oct 14, 2003 | 11:35 AM
bwalsh's Avatar
Realy? That is good to know. What do you have for shocks?
Old Oct 14, 2003 | 11:45 AM
MaxSE03's Avatar
I was going to call someone at Eibach but they have this listed on their site:
Only simple linear springs have a spring rate. A sophisticated progressive Eibach Pro-Kit spring has a load/deflection characteristic. The special design parameters are only accessable through Eibach Desk-Tech Database to Eibach’s exclusive partners.
Old Oct 14, 2003 | 11:49 AM
bwalsh's Avatar
That is interesting. Do you know the differance between "simple linear springs" and "sophisticated progressive ones"? Thanks for the info in advance!
Old Oct 14, 2003 | 11:52 AM
UMD_MaxSE's Avatar
Got Bent?
a progressive rate spring has a variable spring rate depending on how much the spring is compressed. As you compress the spring, the spring rate increases. For small amounts of compression, the spring rate is relatively low. As you compress the spring more and more, the spring gets harder and harder to compress.
A linear rate spring has the same spring rate regardless of how much it is compressed. F=kX, where k=spring constant.
Old Oct 14, 2003 | 11:54 AM
bwalsh's Avatar
So I would assume that Eibachs would be the stiffer spring?
Old Oct 14, 2003 | 11:57 AM
UMD_MaxSE's Avatar
Got Bent?
The Eibach Pro-kit is a progressive rate spring. However, I think that the spring rate of the eibachs is higher than that of the Teins... The fronts are probably the same, but I think the rear Eibachs have a higher spring rate which make them the stiffer spring...
Height doesn't determine the stiffness, but generally speaking, you would want a stiffer spring for more of a drop.
Old Oct 14, 2003 | 11:58 AM
maximadave's Avatar
detailerdaveb@gmail.com
I've had both
The Teins are stiffer than the Eibachs
Luquire's Avatar
it depends for what application
Old Oct 14, 2003 | 11:59 AM
bwalsh's Avatar
Originally Posted by maximadave
I've had both
Are they a lot stiffer. I would like to get the Teins but I thought the Eibachs were pretty stiff with Tokicos....
Old Oct 14, 2003 | 12:03 PM
maximadave's Avatar
Teins/KYB GR2's would be stiffer than Teins/Tokicos. Youll be fine, just trim your bump stops if you go with the Teins. Most people on here are switching to Teins. I went from Eibachs to Maxspeeds and now Teins.
Old Oct 14, 2003 | 12:05 PM
bwalsh's Avatar
Is it a real harsh ride over bumps? And where did you get the Teins?
Old Oct 14, 2003 | 12:06 PM
maximadave's Avatar
No, they are not harsh but you'll notice you have a lowered car. I bought them used from a maxima.org member. Check out some of the sponsors here on the org. Some do sell the Teins or just wait for the next group deal.
Old Oct 14, 2003 | 12:08 PM
Luquire's Avatar
if i got the illuminas that are coming out should i just go ahead and get the teins. i have eibachs right now
bwalsh's Avatar
Thank you all so much for the info!!! Teins it is. One more queston, do you find your car scraping the front bumper?
Old Oct 14, 2003 | 12:09 PM
maximadave's Avatar
sure.........
Old Oct 14, 2003 | 12:10 PM
bwalsh's Avatar
sure.........
Do you bottom out maximadave?
Old Oct 14, 2003 | 12:32 PM
maximadave's Avatar
nope, not at all. Are you in So Cal for a canyon ride?
Old Oct 14, 2003 | 12:38 PM
bwalsh's Avatar
Cool, Nah I am a Boston boy!! Go Sox!!!!
Old Oct 14, 2003 | 12:57 PM
maximadave's Avatar
Yeah, go Sox!
Ask some of your Maxima buddies around your area for a ride....I'm sure someone here on the org lives out there that has the combo you want.
Old Oct 14, 2003 | 03:04 PM
Padsy's Avatar
Boost.....
my H&R KYB combo will be installed friday....
Old Oct 14, 2003 | 04:13 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
teins have a harsher ride than eibachs... ive had both... cant beat the look of teins tho...
Old Oct 14, 2003 | 05:04 PM
HKMax's Avatar
Maybe the bump stop? Hmm, really confusing. I hear people say Teins are harsher than Eibach and some say Eibachs are harsher. Hmm
Old Oct 14, 2003 | 05:47 PM
bk2kmax's Avatar
This is my most recent debacle, whether to get the Eibachs or Teins, I was leaning towards the Teins because I heard that the drop would be lower and more of what I was looking for (front 2" and rear 1.5"). I still wanted to retain somewhat of a stock feel, so therefore I was ruling out the Eibachs but now I'm hearing that the Teins ride harsher than the Eibachs. Do Eibach offer a 2" drop on the front (which btw is the highest part of the Max)?
I've heard that Eibachs tend to sag after putting them on, does anyone know if this is true or does anyone here have that problem?
Old Oct 14, 2003 | 06:08 PM
asu174's Avatar
Clay Aiken has fancy genitals
My Eibachs didn't sag at all. The only beef I had with Eibachs is that the drop was really uneven. I cut a coil off the front springs and it brought it down an extra .75", which put the front and rear at the exact height. Ride quality was not remotely compromised.
If anyone wants to chime in how chopped springs are bad and turn this into a flame war......
Old Oct 14, 2003 | 07:47 PM
kwd2kSE's Avatar
I installed my Eibach/GR2's in Jan '03. Carefully measured before and after drop. Front was lowered 1.75", back 1.0". Have NO sag since. Bad as the roads are here in Houston, would not want to go any lower or have any stiffer ride (especially with the 18's that are going on soon).
Mike
Old Oct 14, 2003 | 08:00 PM
HKMax's Avatar
kwd2kSE, did you cut a coil on the front ones? It seems quite low on the front. Doesn't it supposed to lower like 1.3 inches in the front?
Old Oct 14, 2003 | 08:18 PM
asu174's Avatar
For some reason, 2K2-3s drop less than than 2K- 2K1s do. The Eibach drop actually looks even on early 5th gens. My front only dropped .75" in the front before we chopped them.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
bigdogsteve
Jan 31, 2018 04:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
