just got 18" wheels but dont know offset...
Old Oct 14, 2003 | 03:27 PM
tynant's Avatar
is there an index anywhere of offsets of wheels? How can I find out the offset of my wheels? They are 18X8.5 MASITALY Presidents...they are not yet on the car....I looked at the back of the wheel briefly but didnt see anythign readily identifiable as an offset number....is it always listed somewhere on the back of the wheel?
Old Oct 14, 2003 | 03:28 PM
Jeff92se's Avatar
I'm needing a caw
list everything on the back of the wheel. Anything with a "35" "40" "45" or something is probably the offset. While your at it, measure the hub bore also. Should be at or bigger than 66.1mm
Old Oct 14, 2003 | 05:36 PM
asu174's Avatar
Clay Aiken has fancy genitals
Are you sure they are 8.5" wide? I have seen those wheels in an 8" width, but never an 8.5". Nice wheel by the way....
Old Oct 14, 2003 | 05:52 PM
tynant's Avatar
i thought they were 8.5 but I could be wrong....they have 235/40ZR18 tires on them....do 235 fit 8 or 8.5?
Old Oct 14, 2003 | 06:33 PM
Padsy's Avatar
Boost.....
must be pimp'n wheels
Old Oct 15, 2003 | 05:39 PM
asu174's Avatar
Either. Did you buy them from an org member? If so, those were 18x8.
Old Oct 16, 2003 | 07:40 AM
NYCe MaXiMa's Avatar
He got them from me
Justin,
The wheels are 18 X 8"
i am not sure about that offset, like i said, i got them used myself and there is no offset mark inside the wheel, at least nothing that i could say was the offset for sure.
they sit pretty flush against the fender:
i would guess that the offset is about 38mm? or so? but whatever it is, it's perfect for the max/i30.. i believe the previous owner before me might have had them on with a big brake kit and they cleared it. Also was on JIC coilovers sitting mighty low. I was on them lowered and unlowered, never rubbed, never had any issues at all.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
