aftermarket ignition coil
just want to inform everyone that aftermarket igntion coil are horrible i went through 2 already.
after i replace my oem coil pack with an aftermarket one my car still have a little bass bump while i am idleing at a stop light.
some time it one bass bump other time there like 2 or 3...
shouldnt have bought an aftermarket one....
Originally Posted by outsider
"standard" got it at the local auto store
Finally after about 6 weeks of an occasional misfire at idle, the car threw a code. YEHAWWW!
During this period of time, I tested the coils both hot/cold. Did this about 4 times. All coils tested fine. Tested injectors and they were ok too. Even ran 2 bottles of Techron through th car. But it still had that misfire.
Finally the misfire became worse and I have a code. 0608, cylinder 1 misfire. Switched coil with cylinder 3, reset ecu, and yes! code 0606 comes up. Now I know which coil is bad.
Just went to slavage yard, picked up a coil from a 98 for $25
This will get me though until I order a new set online.
the spark plug is new and the bump is only an intermittent occurance....
it is really annoying though....
do i put the dialetic grease on the boot of the ignition coil or on the spark plug itself?
it me again problem is back again.
i read somewhere how our fuel injector on occasion go bad.
would a faulty fuel injector cause this problem of mine?
this is really annoying me.
thanks
mike
thanks
mike
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
