HELP keep my GF's @ss warm
Allright how do I check if there is current going to the seat and where is the fuse for the seat heater?
Both heaters worked last winter, only the driver one is working this winter.
As for the rest of you stay the hell away from my GF, I make sure her @ss is nice and warm when I'm not driving.
Oh yeah, another thing my airbag light was flashing, I tried resetting it according to the "how to" to no avail. The next day the dealer charged me $80 and told me the passenger side aribag modulator needs to be replaced ($450). He also claimed no other airbags are going to work while the problem is there. On the third day the light stops flahing.
Is there something to worry about or can I just let it be?
Ok so I looked at the fuse under the steering wheel, it looks good according to the haynes manual no breakage in the middle.
I looked under the seat and there are 3 places where wires were plugged in. One at the front and 2 in the middle all 3 were plugged in well. Though how do I figure out if the wiring has gone bad?
Same fuse for both seats, so your OK there.
Does the RED LED light up on the passenger seat switch? If so, you have 12V plus Ground at the switch. If not, I would guess that you have a bad switch or broken wire at the switch.
Does the LOW heat work for both the SEAT BOTTOM, and the SEAT BACK? Wiring diagram shows them wired in SERIES for low heat, and bypassing the thermostat. ( I know, low heat is hard to feel).
For high heat the current runs through the Thermostat and from there (separately) through the SEAT BOTTOM to ground, and also through the SEAT BACK to ground. So on high, if 1/2 the seat works it would appear to be an internal problem in the seat or a bad connector under the seat.
Bottom line, if NO heat at all, on any setting, and the LED lights up, I would suspect the switch needs replacing. Thats what just happened to my SE.
Bob
Bob
Bob
Bob
Thanks btw.
Originally Posted by flyer
The LED lights go on, and I don't get any heat on high or low. How do you change the switch and where is it located?
Thanks btw.
Thanks btw.
To get to the switch you need to lift up the console box that its mounted in. Pry up the trim plate (held by clips) under the shifter to get to the front mounting screws; then remove the two screws at the rear of console.
Good luck, Bob
220k+ A32
18
Sep 22, 2015 11:39 AM
carid
Sep 17, 2015 05:00 AM
97_GXE
Sep 15, 2015 06:47 AM
