transmission or something else ???
Old Oct 20, 2003 | 08:12 PM
djbrown's Avatar
-Da MTL Brown Boi-
i have a problem here
it just started to happen today
it happend twice today
i barely press on the gas and the needle jumps to 4500 to 5000 rpm's before shifting.... all this happen for about 1 sec and then everything come to normal... is it my transmission??
i have a automatic 98 gle
Old Oct 20, 2003 | 08:25 PM
indigomax's Avatar
i think is your valve body and the preassure of the tranny is going bad(you should check it asap)
If you have to press the gas that means the tranny need more preassure to engange.
Old Oct 20, 2003 | 08:29 PM
djbrown's Avatar
-Da MTL Brown Boi-
what i meant to say is that whenever we press slightly on the gas pedal ... the rpm usually go to 2500 to 3000 rpms, but with me it happend twice today that i pressed on the pedal and the rpm jumped to 4500 rpms... which is not normal
Old Oct 20, 2003 | 08:32 PM
indigomax's Avatar
maybe the preassure of the tranny jump up when you press the gas pedal
Maxima99SE's Avatar
will fly for food
sounds like Valve body... get it checked out soon, it'll only get worse. (speaking from experience... I've had many many many transmission problems)
Old Oct 20, 2003 | 08:35 PM
indigomax's Avatar
yes, i have a problem with my tranny...before rebuilt, i use the car like 2 days with the problem....after the tranny rebuild, they told me that the dirty of the tranny damage my VB, and just for a few miles etc. The VB is very easy to go bad, more if you have a tranny problem like that.
Old Oct 20, 2003 | 08:36 PM
djbrown's Avatar
-Da MTL Brown Boi-
so if my VB is bad, i gotta rebuild the tranny ???
Old Oct 20, 2003 | 08:40 PM
Maxima99SE's Avatar
will fly for food
no no.. just get the VB replaced.. unless you drive around too much with it and cause permanent damage.. Mine drove about 10 miles on a busted VB, then had it towed to the stealership and it didn't cause any permanent problems.
Old Oct 20, 2003 | 08:41 PM
djbrown's Avatar
-Da MTL Brown Boi-
how much does a vb will cost.... a rough price.. thx
Old Oct 20, 2003 | 09:15 PM
Maxima99SE's Avatar
will fly for food
not sure on that one, my VB was replaced under warranty, sorry
Old Oct 20, 2003 | 09:38 PM
danthediablo20's Avatar
vb mod
just get one at maximumtuning.com for an after market one if u want...
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
