Uneven Tire Wear and Suspension Upgrade
Old Oct 21, 2003 | 10:32 AM
96max5sp's Avatar
My two front tires have wear on the inside is that a sign of the suspension going? Also how long with the stock suspension last unitl performance starts to deteriorate. Thanks.
Old Oct 21, 2003 | 11:33 AM
LastBoyScout's Avatar
Bump Bump
Well, when was the last time you had your tires rotated??
Im not a tire expert, but it may be caused by improper Camber settings.....
Bump Bump
Old Oct 21, 2003 | 11:41 AM
96max5sp's Avatar
I rotate my tires every 6,000 miles, so I don't think its that, I don't anything about camber settings though, maybe thats it. thanks for replying
Old Oct 21, 2003 | 03:40 PM
njmaxseltd's Avatar
Your alignment is off. When you get new tires, make sure you have the toe reset.
When your car feels really soft and wallows around the road, it's time for new suspension components.
Old Oct 21, 2003 | 03:55 PM
Cool J's Avatar
yep, i also think its the alignment. the 97 2.5 tl acura i was driving had the rear left tire on the inside all te way worn to where you can see the metal in the tires. we got the two rear tires changed and the mechanic said you need a 4 wheel alignment. alignment at sears was $60 but it had not been done yet since they needed to order an eccentric bolt so they could adjust the rear toe.
Old Oct 21, 2003 | 04:34 PM
chris j vurnis's Avatar
You should have the camber adjusted but you'll need some aftermarket parts to do it. You should order some camber adjustment bolts from "TireRack.Com" and have a good mechanic install them. They attach at the bottom of the front struts. The bolt is machined in an elliptical pattern so that adjusting the rotation changes the camber angle of the wheel.
You should run between negative 0.2 to negative 0.5 degrees camber. A slight toe-in of .050" on each tire is also good.
Old Oct 21, 2003 | 11:15 PM
PedalKick's Avatar
Or do what I did, and file the upper bolt holes in the struts so the
steering knuckle can lean outward more. I probably filed the holes
about 1mm towards the outside which was more than enough. Just
make sure the bolts are good and tight.
Maxboy23
55
May 1, 2025 06:09 PM
240tomax
Sep 13, 2015 03:28 PM
thenewguyy
Sep 12, 2015 11:12 AM
Violator
Sep 9, 2015 10:14 AM
