O2 Sensor replacement and Carparts.com
Old Feb 19, 2001 | 11:51 AM
KnowledgeBorn's Avatar
Fuel smelling exhaust and horrible gas mileage - 103,000 miles, I am suspecting O2 sensors...I looked on carparts.com and I don't know which sensor to order. Has anyone ordered O2 sensors from carparts. Can you tell what part number to order under the sensors section and how many do I order/replace for 3rd Gens.....
Old Feb 19, 2001 | 12:48 PM
Matt93SE's Avatar
STFU n00b!
I believe the part # is 13287, but dont' quote me on that.
do a search for oxygen sensor, then find the bosch sensor. it's around $100.
maybe try doing a part # search on the 13287..
you only need one sensor for a 3rd gen.
it's connected to the Y just behind the sway bar. use a 17mm wrench to unscrew. the plug for the sensor is mounted to the rear engine mount. that's about all there is to it.
Old Feb 19, 2001 | 01:08 PM
brubenstein's Avatar
Try here:
http://www.oxygensensors.com/
Cheap too.
Old Feb 19, 2001 | 01:23 PM
Hey Matt,
Does this description sound right???
"Oxygen Sensor, O.E. Type w/Connector; Heated,
BOSCH 13387 $152.50 $99.95 $"
Old Feb 19, 2001 | 01:28 PM
Matt93SE's Avatar
STFU n00b!
yup, that's it!
and yes.. they are heated (as much as people think they're not sometimes, they indeed are).. don't touch it if you've had the ignition on within the last 10-15 minutes.. you'll leave a few layers of skin on the sensor when you jerk back in pain after hearing your finger sizzle!
Old Feb 19, 2001 | 01:29 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Got mine from JCwhitney.com--->
$63 shipped, should be here this week, doesn't have an OEM wire harness but a little splicing done correctly shouldn't hurt!
Old Feb 19, 2001 | 01:43 PM
Do you have a part number from JC Whitney.....Is it the standard or platinum tip sensor...
Old Feb 19, 2001 | 01:53 PM
DA-MAX's Avatar
Here you go---->
its the three wire platinum tip one at the bottom-->
<b><a href="http://www.jcwhitney.com/product.jhtml?CATID=5599">O2 Sensor</a></b>
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
