anyone know what this is?
Old Oct 28, 2003 | 11:26 PM
mungrin's Avatar
96 Maxima runs awesome the other day check engine light came on and it stalled out a few times while drive and only started back up when i gave it gas.Anyone know what it is?Probably a sensor but is it expensive for those?Thx.
Old Oct 29, 2003 | 03:12 AM
JMAXIMA's Avatar
gonna be nice to you... there is a section in the 4th gen forums... at the top... it will tell you what to do when your check engine light comes on... and it will tell you what your code means
Old Oct 29, 2003 | 04:00 AM
maxNYC's Avatar
Just so you don't feel alone, I'm having the same problem on my 95 maxima. Ive been reading the service bulletins and there's several known problems with the 95/96 maximas. Wiring harness, water leaking onto ecu, etc... I'm in the process of having these all replaced and its a huge inconvenience. making me appreciate the car less and less with each problem.
I get 8 different error codes off the ECU so we know there has to be a problem that is triggering it all.
Old Oct 29, 2003 | 06:53 AM
mungrin's Avatar
sorry didnt see the thing on the top.thx for the help.i didnt know that i could check the codes myslef.Everyone i spoke to told me i had to bring it somewhere and pay to put it through a computer.
Old Oct 29, 2003 | 06:55 AM
d_warner's Avatar
Old Timer
Check the Mass Air Flow plug. Friend of mine's car did the same thing.
Old Oct 29, 2003 | 06:59 AM
mungrin's Avatar
man i wish i knew something about cars
Old Oct 29, 2003 | 07:24 AM
NmexMAX's Avatar
dot dot dot ...
You're in the right place. . .spend 6 mos here, read as much as possible, and you'll learn more than you ever did in college.
Old Oct 29, 2003 | 11:00 AM
maguero's Avatar
I had the same problem
Hey, I had the same problem a few months ago. I check engine light stayed on and I noticed the stalling happened sporatically. One day I could drive fine all day. The next it might stall on me twice. It turned out to only be the coolant temp sensor. It cost about $20 and can be changed in 10-15 minutes. If the sensor is bad it can send the ecu a bad reading causing the ecu to retard the amount of gas and spark the engine recieves, thus causing the stalling. The best way to find the cts is to located the hose that comes from the top of the radiator and follow it to where it connect to the engine. It looks similar to a spark plug. I hope this helps,
good luck
