So I went to the track on halloween...
and managed a best of a 13.72 @ 99.77 on my 18" wheels. I watched the video from last night and the one run that the guy managed to get of me was the 13.7 run. Hopefully they can get it uploaded and I will post it asap. Weather was around 55 degrees on this run. I was shocked to say the least. I was in the 13's all night on street tires and I know a 13.4-13.5 is possible as the car sits right now before the ECU
. Is this the quickest all motor street tire run?
02 Auto
Mods UDP, WSP y pipe, b pipe, GAB, HKS rear
slip breakdown:
r/t .5499
60' 2.1314
330' 5.7937
1/8 8.8105
mph 80.63
1000' 11.4662
1/4 13.7273
mph 99.77
I will get teh slip scanned when I get the chance as well as hopefully getting the video posted.
Matt
. Is this the quickest all motor street tire run?02 Auto
slip breakdown:
r/t .5499
60' 2.1314
330' 5.7937
1/8 8.8105
mph 80.63
1000' 11.4662
1/4 13.7273
mph 99.77
Matt
Holy *****!!
Great run(s). Do you have modified VB or do the drop resistor mod?
I can't wait to see what it does with the TS ECU.
Are you thinking about the cams at all?
Way to represent the autos.
Originally Posted by 03BlkSETE
Holy *****!!
02 Auto
slip breakdown:
r/t .5499
60' 2.1314
330' 5.7937
1/8 8.8105
mph 80.63
1000' 11.4662
1/4 13.7273
mph 99.77
Matt
slip breakdown:
r/t .5499
60' 2.1314
330' 5.7937
1/8 8.8105
mph 80.63
1000' 11.4662
1/4 13.7273
mph 99.77
Matt
holy ****!
awesome times. I believe that is the fastest time for an all motor maxima with street tires.
Originally Posted by hakk97se
I thought you said you were on 18's??
Originally Posted by Synki
Congrats on the times. I wonder what it would do if you werent running on 18's.
Originally Posted by spanishrice
Spin like crazy!
Thats amazing
holy **** dude. What do you mean though by "spinning on slicks
I thought you said you were running on your 18's...unless you got slicks on those as well
Just trying to figure out wtf is going on thats all. Those times are amazing man
? "I thought you said you were running on your 18's...unless you got slicks on those as well
Originally Posted by HitManSE
Thats amazing
OK guys I ran on 18" street tires. The reason I said spinning on slicks is b/c I figured Synki knew I had slicks when he said something about using something besides 18's. The other guy said spin like crazy. Then I quoted spin on slicks. I never said I ran on slicks anywhere it was just quoting.
I ran on my 18" nt555 tires
Originally Posted by 2k2SEmax
Matt you forgot to mention that you removed the front and rear seats to save weight
Did you remove the spare tire too? How much of weight savings did all this net you??
So were they...555R or 555ZR
and no I have not looked into what size tires the R's come in. Im pretty sure its the ZR rated though. You know some1 was gonna do this mang, still cant wait for the clip though
There you go, now if some1 else asks we get to flame them
245-40-18 nt555zr's I don't have the cash to drive around on drag radials everyday.
I like Fayatteville. my car ran its best at that track.
opps I posted that in the 1/4 mile forum but it only saved me maybe 80 lbs...ohhh and what happened to your hurricanes
Only 80 lbs.? Like you always say, every bit helps. And why do you have to bring my Hurricanes into this discussion? They played like **** and handed the game to VT on a silver platter. That's what happened.
I think he has some sort of launcher on the front of his car that launches a stick across the finish line before his car does. He pushed a button a split second before he crosses so that he can get a better time.
Shame on you Blu
Shame on you Blu
Originally Posted by kloogy
WTF ! High 13's ?? Even 6 speeds cant touch that !....Whats up with that track ? Thats amazing !.....
) because something just doesnt add up. Its just too quick to see right for an N/A auto. No Matt im not tryin to say your boosted, you've heard that enough from the V8 guys you've beaten. It just seems a little screwy
Congrats good times. Do you really weigh less then a buck and a half
? that may explain the good time slips barely no weight in the car
good 60fts 2.1's, try 2.0's next time, I know is not easy
Kloogs, when I went to North Carolina, folks out there prep their tracks. They go out there clean them out and spray some stuff on them. I had a broken MEVI and was pulling 2.0s 60fts pulling 13.8's @103. The problem was that torque steer was a b...ch. The car would pull left and right because of the compound they laid on the floor, tires would grip. He is using the same tires I use NT555's. I buy that tire because its made of a compound that does not wear down that quick.
