4th gen wheel question
How much does the 4th Gen SE wheel weigh? I have a 1999 and was curious, couldn't seem to find it. Also, where is cheapest place to find some lightweight 17" wheels (I don't care the condition of finish, as long as they are not bent...I am going to powder coat)? I might have to just go with some other stocks. I am trying to buy another set or wheels so that I can keep the tires I have on there right now(all season) for just driving on road trips or anything, and then get some sticky tires on that other set of wheels to swap out periodically. Please advise.
Thanks for your help...
I believe teh stock SE wheels are about 47lbs with stock tires.
You can go to tirerack.com they have some nice lightweight wheels for about 150 a piece.
Select the wheel and some tell you how much they weight. There is some 17s that weight about 17lbs for about $150
the se 5spokes weigh 19.6lbs. Just go here http://www.wheelweights.net/. If I were you I's get the SSR COPMETITIONs. Make sure to get a wheel that weighs a pound or 2 less than the stock one...
Thanks for the info...
IIRC stock 16" gen4 5-spoke is 42lb with stock tires. 19lb without tires sounds abotu right.
IIRC stock 15" gen4 7-spoke sawblades are 14.5lb or so, 38lb with tires I think... I could be wrong though.
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
