Tire Pressure
Old Nov 7, 2003 | 09:39 PM
MaxSpeedSE's Avatar
Tire Pressure
Under the arm rest it says to fill the front tires with 33 pounds of air pressure i belive.
I have aftermarket tires on my 17s, and since they were talking about the 15s...should i Keep that same pressure, or do what it says on the tire?? Its 40 somthing i belive..
-Chris
Old Nov 7, 2003 | 09:58 PM
kwd2kSE's Avatar
The pressure on the tire sidewall is the maximum pressure allowed. I would go with 32 and keep an eye on tire wear to see if that is optimum.
Mike
Old Nov 8, 2003 | 11:12 PM
Bman's Avatar
There are rough guidelines for upsizing tires and how much pressure to put in them based on pressure and load rating.... it's all on a chart of some kind. I'd ask the place where you bought your wheels/tires.
Old Nov 28, 2003 | 04:49 PM
young1976's Avatar
on the factory 17" tires, I think 32 was recommended... You can use that as a reference. I put 34 lbs in mine.
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
