gas pedal feels weird "
Old Nov 13, 2003 | 08:16 AM
enjoi's Avatar
i have a 1997 maxima SE.. i jus bought it from a pre owned dealer.. the suspension feels a bit rough over bumps ... is this normal?? i brought it to the place and they said it was normal.. another thing.. the gas pedal feels different then my friends maxima..when i push down the gas pedal (its hard to push) then it like takes off.. in his maxima , u can just shove the pedal to the floor and it takes off.. any ideas? its kinda makin me mad
Old Nov 13, 2003 | 08:21 AM
XXXL Cracker's Avatar
IMO opinion a stock Maxima has a very smooth ride. Once you add aftermarket performance struts and springs that all changes. I would check to see it has aftermarket supension on it first.
Gas pedal should be smooth without any hesitation or lag. You may want to start the car, open the hood and push your throtle cable to see if it getting caught up.
The throttle cable runs parallel to the opening to your intake manifold. Where the your intake and intake manifold met it is a cable which sits on the front side of the throttle body.
If you are unsure hwere it is, go and get yourself a Haynes mahual.
In the Haynes manual you will find some troubleshooting tips to diagnose the problem.
Big Cracker
Old Nov 13, 2003 | 08:31 AM
enjoi's Avatar
Big Cracker
im not so worried about my suspension.. but the gas pedal is becoming to be a huge issue to me.. (this only happnes sometimes. like if i am not driving or i park it to go get some food or whatever.. after driving it , it eventualy goes away)...still no ideas ) :
Old Nov 13, 2003 | 09:48 AM
NmexMAX's Avatar
dot dot dot ...
Try lubricating the throttle linkage.
Old Nov 13, 2003 | 09:53 AM
twiggy144's Avatar
throttle body needs cleaning?
or: disconnect the gas pedal throtle cable from the throllte body. Then pull on the cable to see if it moves freely. Then from inside the car depress the gas pedal to see of the stiffness is still present. If it still is, the problem is probably inside the "tube" ( dont know the name) the gas pedal cable runs into. Maybe try to lubricate with light oil this cable inside it's "tube" ,
Old Nov 13, 2003 | 10:11 AM
Jatan's Avatar
Do a full tuneup with NGK plugs and clean the TB & IACV. Check for a knock sensor code. Make sure you're using premium gas
Old Nov 13, 2003 | 10:16 AM
NmexMAX's Avatar
dot dot dot ...
Wow that about sums it up JaTaN !!
Old Nov 13, 2003 | 01:34 PM
JonnyCum Lately's Avatar
I'd 2nd the recommendation to clean the TB, especially since he said the problem goes away after the car has warmed up. I had the same problem last winter when the weather was cold. The accelerator pedal feels like it stuck, so you have to push harder to make it move. Next thing you know the car is accelerating like a ****. The problem goes away only after the carbon built up inside the TB warms up and gets soft. The Motovate site has excellent directions for cleaning.
JoshG
51
Sep 21, 2015 10:41 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Lilfatz301
Sep 18, 2015 08:06 AM
Maxxx10
Sep 13, 2015 03:16 PM
slowlifer
Sep 8, 2015 05:53 AM
