Anyone ever had a transmission leak????
Well, I thought my '95 SE was leaking oil, at least something, but it turns out I have a transmission leak. The leak is on the bottom of the transmission where the two sides are sealed together. Has anyone else had the problem before with the VQ? The previous owner had the tranny rebuilt, but it's acting up for me now. Will they have to replace that the whole bottom piece, or can that be sealed? How much $$$ should I have to plan on spending? Later, Steve
Hope this helps
You could do it yourself they probably put the gasket in and tightended the bolts too hard that would create small arches between the bolts and the gasket can't expand enough to compensate. Try that gasket in a tube stuff it worked for me, you just put it all around and it turn's into rubber.
yep common defect
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
