Rpms moving when i stay in one spot..
Old Nov 25, 2003 | 09:34 AM
dss42's Avatar
I have a 5 speed.
Every 2-3 mins the car gives its self gas when its standing. The rpm guage shows its going up a little bit then back down??? Should I be worried.. Car has a auto to 5 speed conversion on it.
Could it be the engine pulley? The belts were changed 1 month ago..
Old Nov 25, 2003 | 09:36 AM
infinitiblast's Avatar
If it only happens ever 2-3 mins I wouldnt be to worried about it...try cleaning your tb though and see if that helps.
Old Nov 25, 2003 | 09:37 AM
dss42's Avatar
It was clean when I put the CAI on a few months back.. What is the best way to clean it?
Old Nov 25, 2003 | 09:47 AM
USRacer900's Avatar
Originally Posted by dss42
I have a 5 speed.
It could be your TPS (throttle position sensor). A friend had a brand new Rav 4 and did the same thing when she started it up. It would fluctuate up and down about 500 RPM. Dealer said it was her "automatic choke" and that it was the car's way of warming itself up. Funny, seeing how it was fuel injected and most auto manufactures quit putting auto chokes on cars 10 years ago. It was the TPS after all. Hope this helps.
Old Nov 25, 2003 | 09:49 AM
dgeesaman's Avatar
Maintenance Monster
Take off the intake assembly and don't damage any seals. Shoot the valve wings with carb cleaner, then carefully rotate them and rub off any dirt around the edges. Be very careful because the machined edges of these pieces are quite sharp.
Old Nov 25, 2003 | 09:50 AM
dss42's Avatar
hmm how much are those and will it cause a problem if i dont change it? my check engine light has been on ever since my conversion never checked it.
Old Nov 25, 2003 | 12:31 PM
multiplexor's Avatar
clean the IACV valve while your at it... it only takes like 30 minutes to do and it's good for the car
Old Nov 25, 2003 | 01:01 PM
dss42's Avatar
Too cold out now to do all this will it cause any problems if i drive around like this?
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
