Which Spark Plugs and wires????
Old Dec 7, 2003 | 11:59 PM
Tyrexx's Avatar
Since it's time to change these things anyways, Im looking to give my ignition an inexpensive "upgrade"
I don't care much about the cost because the plugs last like 30k
I'm going to get NGK for sure but should I get :
-Platinum
-Copper
-Iridium
-ALSO What kind of plug wires are the best?
What do you have? and What Combo should I get?
-Thanks
Old Dec 8, 2003 | 12:01 AM
Shadow's Avatar
Um, you don't have spark plug wires. No Maxima from 95 on has ignition wires, they're all direct ignition with coil packs.
As for plugs, just get NGK platinums. Iridium doesn't really offer any benefits, I had Denso iridiums. Just more expensive. Coppers are cheap, but you end up having to replace them more.
-Platinum
-Copper
-Iridium
-Thanks
Old Dec 8, 2003 | 04:59 AM
speedemn's Avatar
I might not be with the majority on this one but I would recommend NGK Copper plugs. You do have to replace them more often, but that just means that you have a "new plug" more often. A new copper is always better than a slightly used platinum or iridium. The cost is also cheaper even if you factor in 3 copper plug changes for every one iridium plug change. Your car will perform better for a larger percentage of the time too, with a newer plug. So if you do not mind the extra 10 min. a couple of times a year, get the coppers.
Old Dec 8, 2003 | 06:01 AM
twiggy144's Avatar
I second speedemn with NGK copper plugs.
Old Dec 8, 2003 | 07:54 AM
Stephen Max's Avatar
Ditto with the coppers. They are cheap and you can change them when you do your yearly compression check.
Old Dec 8, 2003 | 07:58 AM
mzmtg's Avatar
Minister of Silly Walks
NGK coppers here
Part number: BKR5E-11
Old Dec 8, 2003 | 08:56 AM
jrchilin07's Avatar
where can i get the NGK copper plugs.. and how much???
Old Dec 8, 2003 | 12:32 PM
boyzindahood978's Avatar
I say go for the coppers. They're cheap and it really doesn't take too long to change. I got my plugs at Advance Auto parts for less than $2 a plug.
Old Dec 8, 2003 | 12:35 PM
Ask for NGK BKR5E-11. Just tell them its for a 97 altima. It makes it easier for them to find it.
Old Dec 8, 2003 | 03:20 PM
my99maxisnice's Avatar
Just curious, why do we need plugs for the altima?
Old Dec 8, 2003 | 03:34 PM
darrick's Avatar
Dallas Nissan Enthusiast
copper is the way
Old Dec 8, 2003 | 03:37 PM
stephenlc's Avatar
Umm I bought some BKR5ES-11, will those work....
Old Dec 8, 2003 | 05:13 PM
Its listed as a plug for the altima and not for the maxima in they're system. Not too sure of the technological part of it is.
Old Dec 8, 2003 | 06:20 PM
stephenlc's Avatar
I went to the NGK website and they are listed there for a maxima 95-99. I hope they work.
Need help
23
Oct 2, 2015 08:56 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
