Teins vs Progress
Teins vs Progress
I need to know which springs are better for living in New England. Not too harsh and with an even drop. I would love to get 19s for when it's not cold and snowing and do not want to bend rims because of harsh springs. I've heard that 5th gen maxes ride the best with progress springs but look more even with Teins. Im sure the s tech teins are too harsh for a daily driven max in NE. Has anyone seen h tech teins? And are the s tech teins the only ones in this thread where you need to trim the bumpstops?
Originally Posted by irvine78
i think with the S-tech, you're suppose to trim the bumpstops...
NJmaxseltd I think is the guy who does installs in NJ, and HIGHLY recommended the trimming due to the travel length of the strut and the bottoming of the suspension.
Those who didn't trim suffering a shortened travel length of the strut and thus a harsher ride.
I'm going from memory here....but a search on the subject will illicit the correct answer.
I'll be getting these in the next month or two -- hopefully the installer I choose won't screw me on this little item when i tell them to do it.
gr
That looks good. When I lower my car that's probably the setup I'll go with. How much did it cost? One more thing. It sure would be nice to see at least one pic where your front wheel isn't turned. I'm not turning corners all of the time so I'd like to know what it would look like while I'm actually driving straight ahead.
Originally Posted by 1TyteMAX03
Lookin good!!
I'm staying on 17's for now, so I'm thinking the TEINs will be good for me.
The progress looks nice, but doesn't appear to give any noticable drop on the stockers.
My opinion.
The 20's are just SICK.
Thanks again!
gr
gr
gr
The Maxima bump stops are almost 2 inches long. Cutting 1/3 of them or more away still protects the strut from bottoming yet gives you back much needed suspension travel and ride quality.
Spring Rates
Originally Posted by 2k2nyc
Does anyone know the spring rates of both of these springs?
165lb fr/ 200lb rr
TEIN S-Tech:
201lb. fr / 268 rr
Now that I've done that for general populus.....would somebody care to esplain to me exactly how the different spring ratios effect travel and performance???
I think I have the gist -- but I'd like to hear from a know-it-all so I can be satisfied!
thanks,
gr
Originally Posted by njmaxseltd
Bump stops should be trimmed, or replaced with a shorter one in conjunction with ANY lowering spring. You take away suspension travel by lowering, you give some back by trimming the bump stops which makes the car ride better and gives it the ability to absorb larger bumps on a lowered setup.
Progress recommends cutting the stock bumpstops in half, and replacing the larger diameter piece back on the vehicle.
FYI.
Just doing my homoework!
gr
Ben2003GLE
Sep 24, 2015 04:25 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
