Which is better...Stillen RSB or Addco RSB?
Old Feb 28, 2001 | 07:46 AM
Screaminfast's Avatar
The Addco is definitely cheaper, where the Stillen is Adjustable. I need some comments from people that have either...thanks
Old Feb 28, 2001 | 07:57 AM
Jeff K's Avatar
Get the Stillen
if you can spend the money. The Stillen has some very well designed hardware and is easy to install.
The Stillen bar can slide back and forth to adjust for better handleing. I installed both and wasn't impressed with
the hardware supplied with the ADDCO bar. The ADDCO is cheap for a reason.
Get the Stillen!
Contact Got Rice for that part.
<A HREF=http://www.EatRiceZone.com/>GR Racing</A>
[Edited by Jeff K on 02-28-2001 at 10:16 AM]
Old Feb 28, 2001 | 08:11 AM
Kevin Wong's Avatar
For the money, I'd take the Addco
It's really easy to install and functions all the same. I've installed the addco on my Maxima and a Stillen Sway bar on my friends I30 and the addco was much easier. Plus, a week later, some bolts fell off of the Stillen bar and caused the rear to loosen up. Apparently, Stillen's bolt thread was just not enough. We went to Home Depot to get longer bolts to solve the problem.
Old Feb 28, 2001 | 08:13 AM
Keven97SE
I agree completely with Jeff. If I could do things again, I would buy the Stillen one. The hardware is loads better. I've already had one of the mounting u-bolts break on my ADDCO bar. The ADDCO works, but it is a cheap unit.
Old Feb 28, 2001 | 09:12 AM
Dave B's Avatar
Not DAVEB the parts guy
The Addco is adjustable too. All you do is move the outside bushings and mounts up and down the trailing arm. Further back on the trailing arm will make it stiffer and further up will make it softer. I had it both ways and there is a difference. I like it a little softer.
I've had absolutely no problems with mine.
Dave
Old Feb 28, 2001 | 09:23 AM
AndyXXL's Avatar
I have Stillen RSB and love it. No noise or problems at all. Go for a Stillen one.
Old Feb 28, 2001 | 12:06 PM
BigHops99se's Avatar
I had asked the same questions a few months ago...and the feedback that I recieved was that the stillen is the best and is more expensive because the quality is better. I also have a friend who has the stillen installed and he has been nothing but happy with it and the ride is awesome. That is why I have mine on order as we speak.
Old Feb 28, 2001 | 01:05 PM
rockymtnmax
My Addco is on the way, $140.00 shipped.
I'll keep my car 2-3 years more so I figure the Addco will
work just fine for my driving style.
Old Feb 28, 2001 | 03:07 PM
About how much is everyone paying for the Stilen one?
On a side note, anyone think that putting the polyurethane bushings on the FSB helps?
Thanks.
Old Feb 28, 2001 | 03:36 PM
psu max's Avatar
hey, out of curiosity rocky, where'd u get it for 140 shipped?
thanks
Old Feb 28, 2001 | 07:01 PM
rockymtnmax
swaybar.com ask for the maxima.org discount.
Old Feb 28, 2001 | 11:57 PM
Eric L.'s Avatar
I have the Addco bar and I think it is excellent. As for the quality, in my opinion it is flawless. Installation wasn very easy, and the hardware is top notch. One thing I like about the Addco that the Stillen does not have is that the Addco is a solid metal bar, whereas the Stillen is a hollow tube. I'm not sure what effect that has on overall performance.
The bushings on the Addco are pretty sturdy. I've had my RSB for 3 years now and no problems so far. The Stillen doesn't have bushings so the handling may be a little more sharp (and I mean a *little*). The Addco bushings may also dampen some of the creaking noises associated with RSB's under heavy cornering.
There's nothing wrong with the Stillen bar. I'm sure it is excellent. But in my opinion the Addco bar is also a great choice...it has excellent build quality and materials.
I paid $160 for mine when it was first sold by Cattman.
Old Mar 1, 2001 | 04:45 AM
nixima's Avatar
I installed the Addco RSB last week before I left the country. I drove it for just one day but immediately felt the difference. I have it set in the middle and I am happy with it. The hardware that came with it does appear to be a little on the cheap end but as long as they function I have no complaints. I paid less than $150 shipped.
Old Mar 1, 2001 | 09:14 AM
Do both of the sway bars come with polyurethane bushings? My friend said to replace my front ones cause that is cheap and it helps a whole lot, does this apply to the rear ones?
Old Mar 1, 2001 | 09:30 AM
rockymtnmax
Addco for sure has polyurethane and I think you could choose rubber bushings on the Addco if you wish.
Dont know about Stillen.
P.S.- fstb from procarparts just arrived.
Will install asap. seems very good quality.
Old Mar 1, 2001 | 10:04 AM
i meant the front sway bar, which is the lower one, as opposed to the FSTB, which ties the top of the struts....
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Ramius83
Oct 19, 2000 09:42 AM
punkdork
Sep 25, 2000 02:49 PM
