Wind Noise from passenger side rear???
i've had this pretty bad wind noise from the back window on the passenger side for the past couple of days now... almost like the window is open a little bit (it's that bad)... and it started suddenly out of nowhere... i've read about lots of people who have had wind noise problems... is this what typically happens with u guys too? or is something wrong with my door/window??? i've opened the door and windows several times and closed it back up.... nothing is caught in there that i can see.. but when i drive at medium speed and up, the noise is pretty noticeable.... will the wind noise tsb help?
Here is the link: http://www.atalla.net/maxima/WindNoiseTSB.pdf
There's a sticky posted with lots of the TSB's and this one is in that list. I have my car in the shop today for right rear wind noise and some other stuff. The advisor said they keep repair kits on hand and it's no charge.
My Max has the same wind noise from the rear passenger side door. What I don't understand is why it didn't make this noise when I first bought the car. Suddenly, one day, the wind noise started. Anyway, I'm assuming the dealership can fix it.
[QUOTE=sweeper]
There's a sticky posted with lots of the TSB's and this one is in that list.[QUOTE]
http://forums.maxima.org/showthread.php?t=29351
Most of you guys have been on here long enough to have heard something about this issue. Check out the TSB's and quit being lazy and just take your car in and have the dealership fix it. I had the same issue, made an appointment with the dealer, and it's 100% fixed. Just do something about it already.
After looking over the TSB, I am going to just order 2 of part # 80339-2W100 from DaveB because.....
1. I can fix this myself.
2. I can't be without my car.
3. I don't trust dealers with my car.
At this point, when my MAF finally goes, I would rather pay $80 for a new one from DaveB then have to mess with taking it in. I will do anything to avoid dealer visits.
Originally Posted by bigdo26
What is the part that needs replacing? Maybe I'll just do my own fix on that too, since the dealer is a pain to work with
Thats what I figured. Strange that its only one door that does that tho... So couldnt I grab some weather stripping from Home Depot and do it?
I have a 2002 and it has really bad wind noise. I have taken it in three times to differant dealers and they can't seem to fix it. What ever the so called fix is does not work. I just learned to live with it. I just turn up the music and drowned it out. That is the only fix that works for me.
How do I take out the rubber striping? Do I just pull out it with pliers or dig in with my finger nails and pull out. or Do I pull out the the chrome molding? after it is out, do I just push it back in. I just don't want to rip the striping . thanks need help!
[QUOTE=SEmy2K2go][QUOTE=sweeper]
THE TSB DOES NOT WORK. Taking it to the dealer is a waste of time. I did this three times I know.
ok i just went out....mine started making noise again...last time i fixed it i used vynil foam tape....the problem with that type(same as they use with the TSB) is after time it deforms, now i used poly foam tape. this stuff doesnt deform..we'll see how it will hold up...i'll drive it this evening and report back tomorow if the wind noise has gone away
Starrider
Sep 17, 2015 07:26 AM
lux97Max
Sep 14, 2015 03:54 PM
RealityCheck
Aug 5, 2015 06:18 AM
