Anybody ever got a CEL code 0707 (Rear Heated O2 sensor)
Anybody ever got a CEL code 0707 (Rear Heated O2 sensor)?
My 95 Max hit 100K miles on Christmas day and then today I get a CEL for the first time. I ran the code and got 0707 which the ECU Error Code Decoder defines as "Rear Heated O2 sensor" and the Haynes Manual calls "Downstream oxygen sensor or circuit fault" or "Downstream oxygen sensor circuit slow response fault."
Has anybody had this code before? What do I need to do? Just replace the sensor? If so, how difficult of a job is it going to be? Thanks in advance.
Brian
Brian
yes been there. its one sensor in the cat that needs to be replaced. All you need is the O2 sensor and an O2 sensor tool (usually 1/2" drive) and ratchet. the tool is basicly a deep socket with a chunk taken out for the wire to pass through. it should take you all of 30 minutes. its located in the cat, has a wire comming out of it. jack up the car, use jack stands!! just disconnect the wire, remove the old sensor, and intall the new one and hook up the wire. use some antiseize on the threads of the new one too.
The tool is nice but if you're careful a wrench should work well too. Just be careful with the leverage needed. At 100K your's is probably pretty well stuck/fused on there.
Of course if you have a meter check the sensor before replacing entirely. (but it's probably bad)
nissan uses bosch o2 sensors from the factory..so buy that one.. its should be 60 bucks at online stores. i think i went to foreigncarpart.com.. u could buy the more expensive ngk one.but tis no point when bosch makes the factory one.
Brian
Brian
When you reinstall the sensor, don't overtorque -- it can cause failure of the sensor. Spec is 13-17 ft-lbs.
Clear the CEL after you're done.
James South
95 Maxima SE (mine)
96 Maxime GXE (wife's)
72 Datsun PL510 (fun car)
http://www.oxygensensorwholesale.com...maxima_se.html
55 bucks.. there u go.. have a good day..
dealer price was 100+ if i rememerb right.
Originally Posted by boris
Be careful, these sensors will not fit your car because of the different thread size. Either the O2 tools, they are larger (14mm vs 12mm, if I can remember well). Be sure, it’s the rear O2, for in cat installation. You don’t need to remove the seat: just pull the plastic grommet out to locate the electrical connector.
Originally Posted by Eric425
No they don't. Nissan uses NTK (division of NGK) from the factory. My sensors haven't been changed before, and they are all NTK. Bosch is just OEM style, not OEM. Also, the link you gave is for the pre cat sensors, the two in the y-pipe. The guy needs the sensor behind the cat.
On http://www.buyoxygensensors.com/ they have 2 Downstream Sensors. One by Walker (part # 250-23505) that it says is OEM for $59.99. The other is by NTK (part # 250-23880) that is labeled Universal for $79.90. Should I go with the more expensive NTK over the Walker? I just want the best part and will spend the extra dough if necessary but if there isn't going to be a difference then I'll go with the cheaper one.
This is exactly what I’m talking about. They both will not fit our car. I’ve made this mistake myself, ended up at auto part store, where I could see directly what I’m buying.
You're also saying that these 2 from www.buyoxygensensors.com that say they are downstream sensors don't fit either?
Here is where I ordered it from and then got the returning troubles.
Damn. OK, can somebody please tell me where I can get one that will fit from at a good price since buyoxygensensors.com doesn't seem to be a good place to get them from?
Boris, what are you saying? There's no replacement sensor available for the rear o2 sensor? That can't be right. Where'd you finally end up getting your sensor?
Hey if there's no available sensor, why don't you take your old one, bring it to a dealership to look at their sensor, check to see the threading matches, then get the part number from them? I thought it was 24072 (NTK), but go have a look to be sure.
r u sure the cat sensor is different than the y pipe senors?.. i bought the boscj one.. it fit great in my stillen y..
and im positive, at least on teh 95 that bosch makes the factory y pipe 02 sensors.. i still have my old ones. they say nissan on them.. and they are bosch.
Yeah the cat sensor is different. Different lengths, the plug in looks different, etc. How do you know that the sensors you have are bosch? Just cause they look the same? Or is there actually a bosch badging on it? None of the sensors on my car say nissan, or the oem fuel filters I buy from Nissan or headlight sockets, etc. Just made in Japan. We know that Nissan uses NGK spark plugs from the factory, it'd make sense for them to use the same manufacturer for all it's applicable products. But hey, it don't matter that much as long as it works. If we really wanted to know, we could call nissan and ask specifically.
Originally Posted by 95bluse
You can do like I did and reset the CEL. I switched to Sunoco 94 and the CEL doesn't come back on as often as it once did. The rear 02 sensor has no effect on performance or fuel mileage, it's there for diagnostics only.
I should have tried this when I pulled the code. Hopefully if I do the reset it, it won't come back and I won't have to worry about finding a replacement sensor.
Reset ECU and it hasn't come back
Just to update incase somebody gets this code in the future and refers to this thread. I went back and reset the ECU like I should have done after I first pulled the code and the CEL hasn't come back. I guess it was just a false alarm. Thanks to all for your help.
how long has it been since you reset your ecu? i did it to mine and after a while the light came back on. but even after it came back on it wasn't affecting my performance so i didn't worry about it. i should try switching to a higher octane gas.
help me out guys, http://forums.maxima.org/showthread.php?t=275876
kjlouis
Nov 24, 2018 06:09 AM
Huttig2009
Sep 25, 2015 03:31 PM
doobadoo
Aug 15, 2015 06:43 PM
