got a gtech and messed with it tonight
with a 1st to 2nd gear pull it said i was pushing 186 hp. if i have about 15% drivetrain loss it does equal about 215 crank hp (which should be right for this engine). i tested the 0-60 time and it said 7.23 seconds. stock is supposed to be around 9 seconds (i think). hopefully i can tune it up a bit soon and see if i can crank a few more ponies out of there... might also turn the boost up a bit.
anyone know if the readings will be different between a 1st and 2nd gear pull compared to the regular 4th gear pull on a dyno?
i just did what the instructions said. it said take the weight listed on the car's weight limit thing and subtract 180 for each missing passenger. that put it at about 3,487 pounds or something like that. that's probably a bit heavier than it really is... but i'm not sure.
i think you may need to work on your lauches alittle because if your car has that much power which im NOT doughting it does it should be in the low 6 range 0-60.
to tell you the truth ive never used the HP function i should go try but my buddy just borrowed the GTECH literaly an hour ago so that will have to wait
not to brag or anything but stock i ran consistant 6.6's. With a ypipe, intake, 470 ohm resister and udp i ran a best of 5.9 (on a 20 degree night when the VE was running the best its ever run) with an average of 6.2 on the old motor. With the jdm VE ive been getting consistant 6.2, 6.3's with ****ty tires spining from 2500 to red line in first so with my old yokahamas (which are very very bald) i sould be able to pull more like 6.0 consistantly.
so i would say get to a dyno and see if its putting down the right amount of power to be sure and for sure tune it
i actually didn't try for the best launches i could have which is why they are a bit higher. really, i should be pushing more than the stock 215 for the jdm motor. i have a cone filter and a very high flow exhaust. i'm pushing about 7 psi of boost which i think is stock on the Z, but i'm not positive. i'll have to mess around with it some more.
not yet. bernard is messing with the chips to see if some different programming will run the fuel correctly. for now i just have the stock ecu on the car with the s-afc running really low. works pretty well but it is still a bit rich.
what's weird is i should be able to fully compensate for the difference in size between the stock and turbo injectors with the s-afc but even at -50% it is running a bit on the rich side... makes me wonder if the s-afc is even doing anything.
these engines should have the euro cam with brings the hp up by 10 giving it the 215 stock hp. since the intake and exhaust is better it should be higher than that. but, this is measured with a gtech on a highway. there's no telling how far off it could be.
i have no afr readings at the moment but i can tell by the smell of the exhaust it is running quite rich. sometimes it reminds me of a lawnmower...
I've used a G-tech at the track before and they're fairly accurate in terms of 1/4 mile ET. They usually read about .1-.2 and 3-4mph too fast (ie I run a 14.6@97, it says I did a 14.4@100mph). I've gotten 5.7-5.8 0-60s and I don't put much faith in that.
Launch around 3500-4000rpms, get the car rolling, then quickly release the clutch while feeding it gas. That should net you some better numbers for sure.
BTW, are you ever coming up Kansas City to dyno?
Dave
the gtech only uses the wieght for measuring HP, it doesnt need the wieght for 0-60 or 1/4 miles times
and oyur right about that wieght i bet MTs car only wieghs 3200lbs with him in it which would lower the HP rating on the GTECH. best bet is to take it to the dyno for HP readings but im confident that its 0-60 and 1/4 times are very close
i weigh about 240 so total weight would be near 3320# i suppose. probably a bit more since i have a sound system in there and other junk. hopefully i'll be able to run up to KC sometime and get it dynoed. not sure when though since i'm broke at the moment, lol.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
jsmith24
Feb 1, 2016 12:35 AM
