Will it hurt to add an MEVI to a..........
Old Dec 30, 2003 | 07:00 AM
Cashj2002's Avatar
130,000 mile car??? I am really thinking about getting one. Just need some advice.
Old Dec 30, 2003 | 07:11 AM
mzmtg's Avatar
Minister of Silly Walks
The main side effects will be a slight loss of midrange torque and a gain of about 25 horsepower at redline.
Old Dec 30, 2003 | 07:43 AM
ZuMBLe's Avatar
Just make sure your engine is in good condition. To make use of the VI you have to redline the car. If you don't want to take chances with redlining then don't get it. You may lose some low end power so you would need to redline to make up for the low end loss if racing.
Old Dec 30, 2003 | 08:56 AM
Redmax's Avatar
Redlinemax Owner
there will be no ill effect at all.
Old Dec 30, 2003 | 12:37 PM
Torgus's Avatar
ummm...
ok a mevi is worthless without a ecu
if you do it without the ecu your making your car slower
only do it if you can afford both
if i were you i'd buy a VB mod and an underdrive pulley...which is about the same as a mevi(in price $$$) and will actually make you faster instead of slower(mevi with no upgraded ecu)
thats what i would do...btw your car is hot mod on brutha!!!
Old Dec 30, 2003 | 02:42 PM
maxspeed96CT's Avatar
The original VQ...
wait mevi gives 25hp??
is this on a S/c maxima or something. Or is that at like 7500 rpm with ecu or something crazy.
Old Dec 30, 2003 | 03:44 PM
nismos14's Avatar
§è~® f®ÈÄk
no thats mevi gives 25 hp on a stock car, add ecu and u make more
Old Dec 30, 2003 | 04:32 PM
waveridr85's Avatar
how bout with spraying what will th3e mevi do with no ecu?
Old Dec 30, 2003 | 04:55 PM
TheMax95's Avatar
ok here's how it worksapprox. hp #)
Stock max:
160whp @ 4,500rpm
130whp @ 6,500rpm
Max w/Mevi:
145whp @ 4,500rpm
160whp @ 6,500rpm
Max w/Mevi and ECU:
170whp @ 4,500rpm
165whp @ 6,500-7,500rpm
Again these #'s can be off a tad but you get the idea. You really need both the ECU and the Mevi to get the full benefit.
-Paul
Old Dec 30, 2003 | 05:29 PM
Taken2DaMax's Avatar
wow i really didn't know the benefits of a VI with an ECU. I always thought that there would be a really big loss with the mods. But approx. you would only loss a small percentage of hp at mid range. The high end hp is way more promising than the loss of mid range.
I WANT ONE!!!!!!!
Old Dec 30, 2003 | 06:07 PM
SkyMaxGTR's Avatar
just curious...does it make a difference between automatic and 5speed with the MEVI? are the gains the same with both trannys?
since i have an automatic, i would assume that the MEVI would help the auto more since the rpms takes alil bit longer to rev each gear, since its 4 speed (right?) so on that note, the mod would be perfect for auto racers.
and one more thing. ive heard theres some sort of shift switch or something. do you still need this for an auto?
Old Dec 30, 2003 | 06:25 PM
|Bijan|'s Avatar
UCF Lexus
Yes and no - depends on skill of driver in a 5spd.
The short shift switch - dont worry about that....O/D is good enough
Old Dec 30, 2003 | 08:00 PM
I30tMikeD's Avatar
Originally Posted by Torgus
ummm...
So you have a VI? You ran your car at the track before your VI and you were slower after it? Then you got an ECU with an extended redline and deemed the VI worthless without it?
Why are you misinforming members? A VI will not make a maxima slower. It just drasitcally changes the power curve. A VI will not make 1/4 mile times slower and it will pull much harder after 60 or 70 mph then a maxima with a stock manifold.
Old Dec 31, 2003 | 12:35 AM
EZEMaxima's Avatar
Stock max:
160whp @ 4,500rpm
130whp @ 6,500rpm
Max w/Mevi:
145whp @ 4,500rpm
160whp @ 6,500rpm
Max w/Mevi and ECU:
170whp @ 4,500rpm
-Paul
The Max95,
Do you know what causes the power (HP) to drop at the lower RPM'S if you don't have an upgraded ECU. Can a fuel controller be used instead to cure such a problem. I'm planning on getting the Apexi VTEC fuel controller to control the activation of the MEVI and fine tune the fuel lean/rich conditions before and after the activation of the MEVI.
Eric
Old Dec 31, 2003 | 01:25 AM
meccanoble's Avatar
Sports Button FTW
i have the usual bolt ons (y-pipe, intake). Because i have mods that allow air to free more freely, will i see more than a 25 hp increase since i'm better than stock?
Old Dec 31, 2003 | 02:56 AM
SkylineGTR's Avatar
He's just never heard of a POWERBAND that's all.
Old Dec 31, 2003 | 03:00 AM
SkylineGTR's Avatar
Originally Posted by EZEMaxima
The Max95,
Eric
Maybe the actual runners on the MEVI are a bit shorter than the stock 4th gen runners.
TK
Old Dec 31, 2003 | 12:14 PM
TheMax95's Avatar
TK
Yea I don't know for sure but that's what I was thinking the reason was for less hp in midrange.
Let's get some guys with mevi's to help us out. Any Mevi Pro's out there?
-Paul
Old Dec 31, 2003 | 12:58 PM
Torgus's Avatar
I don't have a mevi. im repeating what I’ve read on here and from the dynographs I’ve looked at, a max with mevi and no ecu upgrade it seemed pointless to lose so much midrange...also as a daily driver loosing midrange sucks imo. But it sounds like you have more experience so preach on. Haters.
Old Dec 31, 2003 | 01:07 PM
The original VQ...
sorry to ***** the thread but sense a mevi won't hurt a car with 130k , but when i get a ecu will shifting at 7,500 hurt it bad. I got almost 140k and my car sees reline at least once each time i drive it.
Also if i have afew bolt on like exhaust and intake and pulley, will i still loose as much hp if i dont get an ecu right away.
Old Dec 31, 2003 | 03:24 PM
I30tMikeD's Avatar
I would not rev out a VQ30 with stock valve springs and retainers to 7500. 7200 is pushing it a bit but I have not had any problems yet.
Old Dec 31, 2003 | 03:26 PM
I30tMikeD's Avatar
Not hating, just correcting your misinformation.
Old Dec 31, 2003 | 08:15 PM
SkylineGTR's Avatar
The reason it looks like they lose "so much" midrange, is because the MEVI flattens out the torque spike that seem to be consistent with stock 4th gens. Try overlaying the graphs and look at losses from 3k-5k. Its definitely less midrange with the MEVI, but the peak numbers are deceiving. That little spike in torque, makes it seem like the MEVI is causing the engine to lose ~20ftlbs to the wheels, when in reality its closer to like ~10ftlbs.
TK
Old Jan 1, 2004 | 10:40 PM
EZEMaxima's Avatar
TK
Correct me if I'm wrong but from experience, short intake runners equals higher HP, or does the MEVI just retunes the whole engine to have an increasing HP as the RPM's increases....
Old Jan 2, 2004 | 12:05 AM
SkylineGTR's Avatar
Longer intake runners will give you more torque at a lower rpm, and shorter intake runners will give you more torque at higher rpms. More is in respect to each other. Meaning you may lose low end and gain top end, or vice versa. Ideally, you would want a variable intake system, with 2 separate runners, long and short, uses the long runners for more torque down low, and then switch to the short runners for more torque up top. Unfortunately the MEVI, isn't designed that way. It uses the 'dynamic supercharging' method. It has chamber(s) measured to a certain length, so that when air goes into the engine, the air hits the valves when they shut, and travel 'backwards,' and go into the chamber, and then bounce back into the engine when the valves open again, so in essence you send the air that was bounced back with the next wave of air. The size of the chamber, the length, is designed to reflect the air back at a certain rpm, and this is where the MEVI gives more top end. The chamber(s) opens only at a set RPM, so until the chamber(s) open, the manifold will act as any other single stage manifold. Anyone feel free to jump in and correct me, but this is my understanding of it thus far. But since the MEVI acts like any single stage intake runner until the chamber(s) open, thats why I guessed that maybe the runner lengths themself were shorter than the ones found in stock 4th gens.
TK
Old Jan 6, 2004 | 07:44 AM
Cashj2002's Avatar
So does it matter which Chip I get?? Are yall saying get the JWT(with redline pushed to 7500) chip instead of the Technosquare?
Old Jan 6, 2004 | 09:00 AM
plurco's Avatar
it not a chip. it is a replacment ECU.
Old Jan 6, 2004 | 10:35 AM
NmexMAX's Avatar
dot dot dot ...
This has been talked about too much, our MEVI does NOT have shorter runners, kinda like our rear suspension, not independent, yet not a solid axle, just one of those things, read up on it a few posts up.. SkylineGTR pretty much summed it up for you guys. The MEVI also seems to benifit the auto more because of its longer gears, so most if not all auto people would not be slower with MEVI, actually faster.
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 30, 2015 08:12 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
