How many of you installed a Glass/Shock Sensor to Stock Alarm?
http://www.vqpower.com/v2/modules.ph...howpage&pid=13
I was thinking of doing this because it's cheap.. but i was wondering what others might have to say about this mod.
I used this page as a guide:
http://www.rcreations.com/public/CoD...e,0t,P=30.html
I should have done it before my car got broken into, but oh well. I got two sensors for $5 off eBay.
I'm pretty sure I can do it, but I hate if my alarm will start going off just from some thunder and $hit.
OMG the link thing is like 10 times easier then the one on the vqpower. And it's pretty cheap, on the second though I might do it. Some b|tches keep on hitting my car infront of my work all the time.
This is easier then my alarm beep (lol)!!! Question though will it work if someone will try to sit on my car or something?
you bought 2 sensors??
wow, that website is alot easier to understand.
Yo quick tip to the newbies instead of keeping on replying all the time one time after another use the "edit" button to add or change stuff that you have already posted
it keeps the thread alot shorter, and easier to read
Good idea but once something triggers the sensor, ur horns not gonna stop beepin until u turn it off...:-/ What if your in school in a class, or in the mall where ur distant from your car? It'd be perfect if it shuts itself up after a minute or so
See that's another project. I pretty sure you can get some timer thing that will open the circuit on the alarm and just shut it off. But I'm not going to check for it right now
Unless maxima's stock alarm already got the timer on it, I can't tell because I will get *****ed at by all my neighbors for having my alarm on for more that a minute
Pull the button to unlock the hood (don't open it) and set the alarm. When the alarm is set, open the hood and see when the alarm shuts up
If you put it under the hood, then your front will be more sensitive than the rear. I'm planning on hooking it up behind the dash like the VQPower one
It's the same thing since they're connecting it to the hood switch wire, but it's more to the middle of the car so the front is not that sensitive than the rear.
I got 2 sensors from eBay too. Paid about $5 for one, but the seller sent two
It's the same thing since they're connecting it to the hood switch wire, but it's more to the middle of the car so the front is not that sensitive than the rear.I got 2 sensors from eBay too. Paid about $5 for one, but the seller sent two
Originally Posted by XoPtOn
cool i just order a Shock + Glass sensor from the link on top, cant wait for it to come ^^
and tell us how long it took you and if it was easy or not.
alright, i got my sensor today, and i want to put it under the hood, can som1 point out to me to what wire i have to connect it to and where do i plug in the red wire, it says 12v but what does that mean, do i need a battery or something? i have some pics
melteye
May 16, 2016 12:02 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Anyone else experience this?
