doesnt wanna go over 3000 rpm ?
Since getting my new catback (2.25") two days ago...i been noticing my car's not been wanting to go upto 3000rpm as readily as it was doing with my leaking catback with two 6 inch gashes. Is it the new catback or the -10F weather for the past two days?
Originally Posted by 93max
maybe the ecu needs to adjust? or maybe ur o2 sensor got messed up while the install
how long does the ECU take to adjust?
Shouldn't take that long at all. If anything, just disconnect the battery overnight, reconnect it, and that should reset your ECU.
Now, are the RPMs not going past 3k all the time, or intermittently? Reason I was asking, was because I had that happen to me, and it turned out to be a faulty MAF unit.
oh yeah it ultimately does get upto 3000rpm and past it...but its just taking longer to get there ....and seems to not want to. the car feels heavier sorta. tire pressure is correct too.
I looked at the air filter and it was full of crap so i had been thinking it was that causing the problem. But i got a new air filter from Nissan today and that didnt fix it at all.
eh i know what ur feeling, my car is running like that now. it happened after i washed my car it seems to be running better than b4 hopefully it something that got moisture in it an needs to dried out. check vacuum lines? or maybe u were just getting better flow with the gashes ^_^
lol...yeah...the leaky catback was "high flow" alright! sounded nice too!
well this is the latest...
before warming up completely, it accelerates real nice...but after about 10 minutes of driving...there is a noticeable decrease in torque.
i know there was a thread about a similar problem some time ago...but i cant find it. did someone find the cause of this issue with their maximas?
knock, knock!
so which sensor are we talking about? 02? dont tell me its the engine temp sensor....cuz i put a new one in September from Nissan.
Originally Posted by Jeff92se
Try a 470ohm or 550kohm resister installed in the ks connector harness. Easy to do and cheap to buy. Also clean off the red coolant connector
the knock sensor is above the rear exhaust manifold on the VG?
coolant connector?
yup...
i do have the factory service manual...it shows a detonation sensor , i am guessing that is the knock sensor? thats the one on rear engine bank above the manifold according to the manual
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
