JWT Cams
JWT Cams
i know some one in the fourth gen forum installed the jim wolf cams in their max but since the search is down i couldnt look it up. Anyone have installed or dynoed these? They sure are expensive and for 1k i hope they give good gains. Since this isnt really an exhaust mod will it give better low end torque and accelaration?
Watch these movies and listen to Ironlungs car. This is with Catback, headers and cams. Right click and save target as...
http://team310.com/maxima/matt003.mpg
http://team310.com/maxima/matt004.mpg
Originally Posted by GreekMaxima
fuc*ing niceeeeeeeeeeeee!!!!!!!! he has custommaxima dual exhaust? very nice max!!!!!!!!!
is it a member?
www.cardomain.com/id/ironl40
Steve,
Who installed his cams?
Originally Posted by Y2KSESteve
Thats a custom exhaust, not the custommaxima exhaust.
Auuuugh ha! Got it..thanks!
I'm sure I know the answer, but he did NOT remove the engine to install them correct? What would be an approximate install charge for cams?
Matt does all of his own installs and all of ours. He could raise the idle a bit, but he really likes the sound as do I.
Originally Posted by NCTRNL
Yeah, it sounds good when it idles, but the rest sounds like ***. Why would you want your car to sound like that? The loping...good...the rest...BAD
i believe the 95-01 share the same engine internals. the jwt website lists ONE set of cams for the vq30de only:
S1 VQ30DE BILLET CAM SET 256 DEG .415" GROSS LIFT. LASH .013" COLD .016" HOT SLIGHT LOPE AT IDLE (TARGET IDLE SHOULD BE 900RPM). RUNS...
Only difference between the vq30de and vq30de-k should be slighty different timing, but i'm fairly sure cams would work
2k2-2k3 vq35de guys have their own set of cams from jwt and also from nismo (350z)
litch
123
Jan 4, 2024 07:01 PM
Mahmuth
Sep 25, 2015 10:08 AM
