motor and trannie longevity and where to find rebuilds of both?
ok, so i'm new here and pretty new to nissans. i originaly baught my 91 about 4 years ago, sold it to a so called friend who pretty much neglected any and all maintainance, and then recently got the car back (for free). so now it has 166k, it has the auto transaxle. it still runs great and shifts well. i am keeping the car for my daugter who will be 16 next month. anyway, here are my questions:
how many miles, on average, can i get out of it? i know a lot of variable come to play, but give me a ballpark.
how well does the auto transaxle hold up?
when they do give up the gost, where is the best/affordable place to replace them? i don't need any exotic motor swap, i like the power of the motor, would just want to replace it with a remainufacted deal. same with the transaxle if it goes south.
thanks
thanks
if the tranny goes out and you feel you must put an auto back in it, you'll probably shell out $1200-$2500 to get it rebuilt..if you can find an 89-91 SE with a good 5 spd you can change the clutch parts and have it swapped/swap it yourself and save some money..
As for the engine, well, you should have a good long time before you need a new one, unless it was seriously abused (I don't mean leadfoot abused, I mean 6500 rpms no less all the time kind of abused)..quite a few maximas break the 400k miles point, and almost all can break the 300k point..
Ditto what Golden Ice said. My recent tranny rebuild was $1800. My engine has about 180K on it, and it still runs like a top. You might look into a tranny flush and adding a tranny cooler in order help add life to it.
Used/rebuilt trannys and engines are available on the web- ebay, etc.. just have to be a little cautious is all.
sweet! thats great to hear! ok, i want to know more about the 5 speed swap and i'm sure its been covered a bunch so if anyone has a link to some good threads or cares to cover it again for me that would be great. thanks for the info!
jason
its a long process to explain..if you look back a few pages you should be able to find a thread discussing transmission transplant, trans conversion, somthing along those lines..remember, you have a VG30E engine, so you want to look for an 89-91 SE for a parts car so everything bolts up..I think the only holes you have to drill are for the clutch master cylinder..I'm told there is already a clutch pedal mount in all 3rd gens, but I dunno about that..
thanks
thanks
Interference engine and timing belt!
With a 166K on the clock you better hope it been changed at least once, and hopefully twice. If the timing belt breaks the motor goes buh-bye!
Originally Posted by shoult
Being a VG I have five words for you...
i was planning on doing the timing belt. what do you mean by interference engine?
if you know a fair amount about engine mantianece and doing the qword yourself you could proboly do it if you buy some sort of book to help. id set aside at least a whole day but it should only take 3 or 4 hours and make sure you change the water pump in the process
what makes the vg30e have such a crappy belt. the manual says you have to replace it every 60k or 2 yrs.
Lots of motor experience- just on small block chevys. i checked out my haynes manual and it doesn't look too bad. just so much crap packed into a little space. LOL!
Belts will typically run 100-125K before breaking, but with an interference engine you DON'T want to chance it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
ffcbairn
Aug 16, 2015 09:29 PM
