95 JWT ECU in 97 Max - what codes to expect?
Old Jan 19, 2004 | 02:14 PM
iansw's Avatar
What the title says.....
Installed 1995 ECU in my 1997 Max and I only get one code - 1005 - EGRC Solenoid valve.
According to the 4th Gen FAQ's, that code would show up on a 99 because 99's have a different type of EGR System. But it doesn't mention any EGR differences between 1995 and 1997.
Basically, I had expected a rear O2 code.
Anyone else put a 95 ECU in a 97 Max? What codes, if any, did you get?
IanS
Old Jan 20, 2004 | 06:48 AM
Stephen Max's Avatar
IanS
Is that the code you get from your JWT modified ecu? I started getting the same code after sending my ecu to JWT. Just the code, not a CEL. I never got it before having it modified.
I went ahead and replaced the solenoid valve anyway, but I still get the code. Functionally, the car drives fine with no indication of any EGR problem. I had come to the conclusion that it's a bug in JWT's turbo program, your experience confirms that.
Coincidentally, I always used to get a CEL with 0707 (rear heated O2 sensor) before, now I never get that. Weird, huh?
Old Jan 20, 2004 | 11:34 PM
iansw's Avatar
Interesting. I jsut realized that the 1005 code also is not throwing the CEL. Other things were - like my broken wiring for the Samshaft Position Sensor and then later the blown coil pack.
Well, that will fail me on emmissions.....so now I gotta think ahead to September on what I have to undo/re-install before Emissions day.
Old Jan 23, 2004 | 05:39 PM
iansw's Avatar
Yep - 3 days now - no CEL with a 95 ECU in my 97!!
Old Jan 23, 2004 | 05:42 PM
Bags's Avatar
VG Ridah's Biatch Hoe
There are ways to PASS emissons
Cost is apporx ~$100.
From what I have been told
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
