Adjustable rears / non adj front struts
Old Jan 20, 2004 | 08:18 PM
ssilva420's Avatar
Is it ok to have rear adjustable shocks, and non adjustables in the front, while all struts are on sprint springs. I have agx in the rear with tockico blues in the front. Just wondering if this is ok or if anyone has done this.
scott
Old Jan 20, 2004 | 09:02 PM
RastaManMax's Avatar
That would be interesting to say the least, a rear end which is planted and a front end with OEM replacement struts and sprint springs. You're a pioneer for real, just swap out those blues when they blow for some AGX or Illumina fronts.
Old Jan 20, 2004 | 09:12 PM
nick's Avatar
I've had this combo for while now:
- front Tokico hp's , back KYB AGX with Sprints
than i had H&R springs
and now i'm on stock SE springs - but i'm replacing the rear KYB AGX with stock SE struts
Nick
Old Jan 21, 2004 | 06:43 AM
endus's Avatar
An atavistic endeavor...
You could probably do it as long as the valving was similar...BUT I have to say that I have not messed with the AGX's on my rear that much, but I have on the front and the front makes a MAJOR difference in the handling of the car. Going from 2 -> 3 made the turn-in on corners significantly tighter...like it's on rails. All other things being equal I would rather have the same adjustable struts on all 4 corners./
Old Jan 21, 2004 | 07:06 PM
ssilva420's Avatar
What would you guys recomend i have the rear agx struts set on with the tockco blues in the front?
scott
Old Jan 21, 2004 | 07:58 PM
nick's Avatar
with sprint springs - hmmm try 5 or 6
things will be stiff though.
Nick
Huttig2009
Sep 25, 2015 03:31 PM
kenc15
Sep 25, 2015 06:38 AM
MaxStock
Aug 14, 2015 10:01 PM
laparka66
Aug 6, 2015 09:36 AM
