92 SE intermittent stalling
I have read the numerous post about this common problem and I'm seriously considering changing my coil packs.
Here's the thing though......:
1. Before I changed the injectors I had little power but the car started up easily but ran adn idled rough. Nissan(dealers) said that my injectors were probably bad or not the right ones(which it tured out to be). I changed out the injectors with some used ones and the car runs almost perfect except for the hesistation and stalling it now exhibits.
2. When I first started it up after putting in the injectors, it takes longer to start up. I noticed it had a mis-fire in Cyld. 5, and after reading up on this I'm now looking to replace the coils, but then today, for the heck of it puled each coil wire and the mis-fire is now in cyld.2!!!!????
I'm hoping this is indicating that yeah, the coils are bad/cracked and I sure hope its not the injectors again, so maybe the relay or regulator or ECU...!!! Anyone have a moving mis-fire??????? Why the jumping/moving mis-fire??????
FYI: I have a hole in my flex-pipe caused by the rich gas when the injectors were bad,( likely suspect????) and I've changed the plugs(put in NGKBKR5E-11), Fuel filter and the MAF sensor checked out okay.
Just looking for feedback before I try the coilpacks-coz of the moving mis-fire!!
mrgoogs.
mrgoogs.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
