Pulls to the right - Brake
Anyone know how to test the power of a caliper?
The other day (thank god) I had to dump alot of speed and succeeded(brake hard). I noticed in the split second, that when I hit the brakes I pulled to the right/passenger. It sucked, because I also had to correct the wheel as I slammed the brakes. I replaced the pads and rotors in the front about 4 months ago, and notice no uneven wear. Is this normal to brake unevenly? I believe there are some oem re-seal kits available for the calipers. Any good? Would it equalize pressure on both sides if i did this? How hard is it to do it? Any write-ups? No brake fluid loss is apparent either.
Should I just replace both calipers and hope for the best next time I have to use the brakes? I'm hoping the brake seal kits would work...to save money. No tire screeching occured BTW ( no abs either). Anything I should look for? Maybe bleed 'em?
Haynes manual:
Vehicle pulls to one side during braking -
1. Incorrect tire pressures
2. Front end out of alignment
3. Front, or rear, tire sizes not matched to one another
4. Restricted brake lines or hoses
5. Malfunctioning drum brake or caliper assembly
6. Loose suspension parts
7. Loose calipers
8. Excessive wear of brake shoe or pad material or disc/drum on one side
7. Loose calipers
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
