changing Power steering hoses
Old Jan 24, 2004 | 02:45 PM
jkmay01's Avatar
Lil 8
I was checking all of my fluids the other day and notice that both of my power steering hoses were sweating and wet. I check the power steering resovoir it was low so i filled, but i have no leaks on the ground, so the rack is good i changed that maybe a year ago so that is fine. Needed to know tha procedure am looking thru my manuels for more info. I was going to just re-tighten the clamps first before changing the hoses. Let me know!!
Old Jan 25, 2004 | 01:07 PM
broncoguy's Avatar
You can try tightening the clamps first, and see if that works. If not, changing them is not hard, just messy. And make sure you get the right pressure hose, if you buy aftermarket.
Old Jan 25, 2004 | 01:12 PM
Bman's Avatar
Try this post: http://forums.maxima.org/showthread....power+steering
I might have to re-install mine in the spring because I bet fluid starvation (from not having the bolt lined up) is causing the groaning noise I'm getting.
Old Jan 25, 2004 | 03:06 PM
jkmay01's Avatar
Lil 8
thanks bman i sent u a e-mail about the size of the 2 pressure hoses underneath the power steering resovoir? I looked thru my chilton and haynes but they didnt touch specific on the changing of them or there sizes. Also, which is the low& high pressure hose? There are 3 hoses: 2 underneath the resovoir, and one running to the rack.
Old Jan 25, 2004 | 10:16 PM
Bman's Avatar
Oh shoot, I didn't know that BOTH of your hoses need replacing. Like most people, I only replaced the high pressure hose that goes from that bracket by the cowl down to the pump. I would just go and buy replacement hoses from an auto parts store, at least for the HP hose for sure.
The circuit goes from the reservoir to the pump, from the pump to the rack, from the rack to the radiator (to cool it) and then back to the reservoir again. Most of it is metal lines like the brakes IIRC and only the HP hose and hose from the reservoir to the pump are flexible. HTH...
Old Jan 27, 2004 | 08:56 PM
jkmay01's Avatar
Lil 8
yea sounds good!! Yea I need to change mine like ASAP I have small sweating around all of the clamps were the hoses connect like at the rack, under the reservoir. But I checked the reservoir today still at a good level, but i dont want to wait on it!! Too damn bad we have a damn winter storm here!!!!
pkfinn
Jan 3, 2016 02:55 PM
iflexsteel
Sep 15, 2015 03:37 AM
Andy29
Aug 31, 2015 01:59 PM
hydriplex
Aug 28, 2015 02:13 PM
scarletsosa
Aug 17, 2015 09:09 PM
