Get Turbo or Supercharged ???
Hey guys ~~!!!
I currently have 99 SEL...
I'm trying to get either Turbo or supercharged for my car....
I didn't get any basic mod such as y-pipe, CAI, Catback etc ...
Which one is better ?? I really have no idea .. ~~~!!! -,.-;;;;
Oh another question, what the hell is psi ??
Thanks ~
Thanks ~
Go to this thread: http://forums.maxima.org/showthread....96#post2654496 .
I had many questions myself so I started this thread a week ago and have gotten good info from it. The subject about which is better has been briefly touched on as well, just read the entire thread from post #1 til end. I'm sure there'll be more inputs to come so just visit the thread frequently.
Hope it helps.
Hope it helps.
Yeah... before you boost your car, you might want to read and educate yourself before you put anything like that on your car. If not, you could risk blowing up your car. BOOM!
well i would go with turbo cause supercharger needs power by the crank to run so it takes away some ponies from the overall hp, but turbo don't. but yea like everyone else said, u should go to the other forum and u would get alot more info.
WOW!!!!
For your car's sake please avoid forced induction at all costs...For now anyway...
Check out www.howstuffworks.com for basic info on forced induction and how and why it works...
Mike
For your car's sake please avoid forced induction at all costs...For now anyway...Check out www.howstuffworks.com for basic info on forced induction and how and why it works...
Mike
Originally Posted by IwANnAMaX96
WOW!!!!
Check out www.howstuffworks for basic info on forced induction and how and why it works...
Mike
For your car's sake please avoid forced induction at all costs...For now anyway...Check out www.howstuffworks for basic info on forced induction and how and why it works...
Mike
I'm a newbie on forced induction myself. I just started reading like crazy. N/A is a very expensive way to draw big HP's from any engine. So unless you have deep pockets like those Nascar contenders, then FI is the next thing. Both turbocharging and supercharging has its pros and cons. Someone mentioned that the S/C is powered by the crank via the accessory belt so running the S/C can cost the engine some ponies, that's true. But there's more: the advantage is instant boost the moment you step on the gas pedal, the downside is that the boost lessens at the higher RPMs. Then you have the turbocharger, advantage = more boost at the top, but lag at the low RPMs, slight delay when you hit the gas pedal. But there are ways to resolve the lag issue. That info came from researching not just from here but from other websites like www.howstuffworks.com . It's just one of those subjects that don't have one, catch-all, answer. Also, visit the Forced Induction Forum .
Originally Posted by maxima98vspec
yea that's true, but if i was gonna go FI i would go turbo, our cars have alot of torque at the start, but we loose alot of torque at the top end so turbo would be a great thing for that if only it was good for our motors.
I read about turbocharging on engines w/ stock internals, and quite a few have done so and claimed to have no real problems. But I'm not really going to chance it. If I'm going to get into the expense of turbocharging, I would do it right the first time and upgrade the pistons, rods, and cams and also the tranny. My VQ has 115k miles now, so adding just the turbocharger would kill it fast. Also, many who have killed their engines were boosted high. Many car's with factory installed turbocharges only run at very moderate boosts to preserve engine longevity. Big boosts involves many many things.
Well the VQ can easily handle 400WHP...
yea hopefully someone comes out with some internals for our cars, we are preaty limited , they have more parts for show than they do in perfomance which is straight up wack. i wouldn't mind spending a couple of grand on a full stroker kit, and who ever comes out with that will have some good business from us, but so far i see more and more intakes, and cheap sh!! like that that we don't really need, we are gonna end up like civics that have a bigger selection of crap that they have a hard time to choose.
Originally Posted by Tom153
get a turbo, even though u will have some lag, ou will appreciate the torque much more
There's a reason why top fuel banned turbo chargers. They were making way too much power. You can run a turbo on factory internals VERY EASILY. Anyone that says you can't is flat out wrong. The only thing you're going to need is more fuel: larger injectors, higher flowing fuel pump, and perhaps an AFPR and you're set.
True but the only main setback is engine longevity. Stock internals just won't hang as long when its constantly under extreme pressure from the boost. I read somewhere that an org member upgraded the cams in his VQ. Now if there's only a source for piston upgrades. We'd be set.
Honestly though, I've turbocharged many stock NA motors that have lasted for years and thousands of miles without even a hiccup. As long as you know what you're doing, you can make your turbocharged VQ to be as reliable as anything from the factory.
You can go on and on about boosting, so it's better if you just read up.
litch
123
Jan 4, 2024 07:01 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
I wish JAY25 would do his job....
