Stuck Antenna
Stuck Antenna
I've seen a few Max's running around with the same problem, so I'm hoping that someone has a cure. For a while, it only happened when outside temperatures were extremely cold. But even then, I was able to give it an assist while the antenna was detracting. Now, however, it seems that it's locked at the last segment. i.e. The antenna will extend all the way, but will only go down to the last section and stop - hard.....I can't push it down at all.
Any thoughts? I don't have a problem with replacing it if necessary, but I'm very curious as to why it locks hard at that last section.
Thanks.
Thanks.
I usually lubed it with WD40 every couple months...Mostly to get the junk off of it, and to keep it smooth. While I understand that it might not extend and detract smoothly if not lubed, and since the radio is on (with antenna extended) every day, I still don't understand how it could get locked up.
Will follow the lub tips. However, I believe I've found the problem. I'm still perplexed at how this can happen, but here's what I did. On a hunch (no cost), I took a hair dryer to the antenna base. Several minutes later, I was able to get the antenna down with a little assist (i.e. pushed down a little while it was detracting). It's working fine now. But I'll tell you, assuming it was an ice problem, it was frozen pretty well...Until the dryer, I'll bet I could have broken it trying to push it down.
Thanks to all for the feedback.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
