Lightweight -not underdrive- Pulley?
Old Feb 12, 2004 | 12:26 PM
MrEous's Avatar
^ Jeff™
Definitely not wanting an underdrive pulley but am looking for a lightened pulley instead. Any ideas?
All the pulleys I have seen for sale all say 'Underdrive'...Darrick and myself are both trying to avoid that due to our systems.
Thanks for any help...
-Jeff
Old Feb 12, 2004 | 12:38 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
-Jeff
It's already been made. Talk to Gabe aka latinmax to find out details or search
Old Feb 12, 2004 | 12:40 PM
MrEous's Avatar
^ Jeff™
lol...of all the Maxima owners that could have answered it was someone else in DNE.
Thanks Joffe...I'll call Gabe. Steve also mentioned that UR Pulleys makes a lightened pulley and an underdrive pulley.
-Jeff
Old Feb 12, 2004 | 01:08 PM
d_warner's Avatar
Old Timer
Yeah Jeff. Unorthodox does make one. But Unorthodox has always been a little steep.
No underdrive? Pansies!
Old Feb 12, 2004 | 01:47 PM
Imobejoas's Avatar
Why is only DNE posting here?
Old Feb 12, 2004 | 01:50 PM
t56gen3's Avatar
Cause few people know about it. Gabe was the only one that knew when I was inquiring.
Old Feb 12, 2004 | 02:04 PM
MrEous's Avatar
^ Jeff™
This would be something important for A LOT of Maxima owners to get in on...mainly the ones with systems.
Is the idea really 'new' to everyone else?
Old Feb 12, 2004 | 02:15 PM
BlueBOB's Avatar
UR is the only one I've ever known to make a lightened pully that was the same size as stock.
Old Feb 12, 2004 | 02:49 PM
t56gen3's Avatar
Not so much "new" as "low demand."
Old Feb 12, 2004 | 04:10 PM
maxspeed96CT's Avatar
The original VQ...
It has ben around for a while, its just no one has it because the gains are probubly less. Not sure but if the price wasn't so steep i'd buy one.
Old Feb 12, 2004 | 04:14 PM
darrick's Avatar
Dallas Nissan Enthusiast
mabe we can get a group deal?
Old Feb 12, 2004 | 04:23 PM
Bmr4life's Avatar
screw a lightweight pulley, i want a lightweight OVERdrive pulley. i need some more amps.
Old Feb 12, 2004 | 04:50 PM
Sniper's Avatar
Is the lightweight pulley as strong as the stock one?
Old Feb 12, 2004 | 09:35 PM
sk24iam's Avatar
What is the advantage of replacing this pulley with aftermarket?
Old Feb 12, 2004 | 09:54 PM
Imobejoas's Avatar
The concept is similar to using lighter wheels on your car. Frees up some horsepower, that is otherwised lost in the rotation of a heavy pulley. An underdrive pulley reallocated the power even more (about 10-15%), but the tradeoff is less electrical power to the alternator and A/C systems
Old Feb 12, 2004 | 10:17 PM
ABK's Avatar
ABK
y don't you guys get an underdrive pulley and put a new pulley on your alternator. I seen it at ABT on of these days. That thing was pricy but I'm sure that are some for cheap.
Old Feb 12, 2004 | 10:21 PM
SXN's Avatar
SXN
technically, if you kepts the same pulley ratio (and got the same ammount of juice) wouldnt the whole system create as much drag as before? the light pulleys would help, but im talking about size
Old Feb 12, 2004 | 10:37 PM
ptatohed's Avatar
Licensed to Spell
:o)
...Uh, what about the ones with SuperChargers???
Old Feb 12, 2004 | 10:42 PM
Eric425's Avatar
Does anybody have any dynos of these things? I don't see how they could produce any power at all. Most of the drag fighting the pulley comes from the belt and accessories that it must be turning, right? If it's the same circumference, then weight would only have an effect on initial inertia. So maybe you could rev a slight bit faster. But it's not going to be like a lighter car versus a heavier one, because with cars, the power is fighting 100% with the car's weight to propel it, so lightening your car directly lightens the workload for the engine. But with a pulley, the workload is not caused by the weight of the pulley, but by the accessories, right?
Old Feb 13, 2004 | 12:26 AM
meccanoble's Avatar
Sports Button FTW
very interested in this
Old Feb 13, 2004 | 06:07 AM
MaximaMoJo's Avatar
How does a underdrive pulley affect the AC System. I wouldn't think that the AC system takes many amps to run. I would think that it would affect the compressor and not the electricals of the AC system. Am I right on this? Is the AC just less cool at low rpms?
Old Feb 13, 2004 | 06:28 AM
t56gen3's Avatar
The single underdrive pulley slows down the RPMs of ALL the accessories---power steering pump, A/C compressor, and alternator. There WILL be decreased output out of all 3 with an underdrive pulley. If you have the stock audio system and are content with that, then an underdrive will most likely do you fine with minimal to no noticable depreciation in functionality.
If you have aftermarket audio amps or anything using above factory level power (any aftermarket electronics) you would be best served by the OEM size pulley.
The power gains are more from the weight savings vs the underdrive. I think this saves about 6 pounds on the crank. Honestly, I would expect about 3-4 whp outta this. It was noticable on mine, but not huge.
Old Feb 13, 2004 | 07:09 AM
The original VQ...
how much worse is it to have asystemwith a underdrive pulley, i have a 1000watt amp wit a L7 12, will be afected noticably? cause i dout the stock size pulleys give any HP.
Old Feb 13, 2004 | 07:22 AM
t56gen3's Avatar
It's your battery, amplifier, and alternator you'd be abusing. If it's in your budget to replace them often then by all means.......I used to be an audio and security installer, and amps generally don't like voltage drop. Then there's the fact that if you are using more current than you are producing then you will eventually run your battery down while driving.
Opinions vary, but generally 85-90% of the power gains are from the weight savings alone. Is your electrical equipment worth <1 hp to you?
Side note: I initally had an underdrive on my car (bought cheap just to test.) At idle I was at 12.6 with nothing on. If I turned on either the A/C OR the stereo system it dropped below 12v at idle. I'm not trashing my amps for <1hp.
Old Feb 13, 2004 | 05:47 PM
ptatohed's Avatar
Licensed to Spell
:o)
Is this English??
Old Feb 13, 2004 | 08:26 PM
The original VQ...
Thanks for clearing it up, so a reguler pulley is outa the question but why doesn't any one have a sock size light weight one??
Old Feb 14, 2004 | 10:09 AM
sk24iam's Avatar
Anyone with a big system ever put in a udp? I just want to hear from soemone who has tried it.
Old Feb 16, 2004 | 04:50 AM
BlueBOB's Avatar
That's what t56gen3 is saying. He ended up getting a stock size lightened one so he would still get the slight gains, but not affect his power output.
Old Feb 16, 2004 | 05:46 AM
The original VQ...
sounds like what I need. Can we get a group deal?
Old Feb 16, 2004 | 06:01 AM
96white's Avatar
group deal sounds good.
Old Feb 16, 2004 | 07:25 AM
MrEous's Avatar
^ Jeff™
I have sent an email to a company that makes lightweight pulleys for WRXs and SRT-4s to see if they would be interested...I'm just waiting on a reply now.
BTW...I found a good article on Motorvate about Underdrive Pulleys.
Underdrive Pulley Report...<---Click
Old Feb 16, 2004 | 08:06 AM
Dave B's Avatar
Not DAVEB the parts guy
The stock pulley weighs ~5lbs and is a crank damper. The UR UDP weighs ~1.5lbs and has no crank dampening materials.
Dave
Old Feb 16, 2004 | 08:34 AM
ptatohed's Avatar
Licensed to Spell
:o)
Dave
What is a crank damper?
Old Feb 16, 2004 | 08:45 AM
D1NOnly34's Avatar
concerning the system issue. I understand hwo it would affect the dorp in voltage, but what if you had an optima yellwo top and a capacitor? And you don't use your A/C too often? Will it sitll be OK? I'm looking at around 1200-1500 watts here, I have a friend with a 5th gen and he has 1500 watts running with the stock battery and a cap. All he gets is dimming, he has the DMS UDP, and he gets slight dimming, but he always has had that. =P
Old Feb 16, 2004 | 08:55 AM
image's Avatar
hrm... D1n, I have 2 1200 watt amps (JBL) and a 300 watt 4 channel amp (JL Audio).... ran by 0 guage to a distro split off into three 4 guage wires ran to the amps.. I have a yellow top and a capacitor. Any of you guys think I will be able to get some pulleys to free up some HP without compromising my sound system? I use the AC a little bit during the summer, Houston, It hot.. Plz help!!
Old Feb 16, 2004 | 09:01 AM
D1NOnly34's Avatar
you're in the same position I'm in =/ The only problem is I already bought the pulley for a good price, but now I'm considering actually putting it on or not.
Old Feb 16, 2004 | 09:02 AM
image's Avatar
can we do a alternator upgrade???
Old Feb 16, 2004 | 09:09 AM
D1NOnly34's Avatar
im sure we can, but i was told that our 4th gen maximas have better output than 5th geners...110 amps something like that..i dunno how much mroe we woul dbe able to upgrade and for hwo much
Old Feb 16, 2004 | 09:11 AM
Dave B's Avatar
It's a ring of elastic material (rubber) sandwiched into the pulley which dampens the natural harmonic vibrations of the crank under various loads.
Dave
Old Feb 16, 2004 | 09:22 AM
image's Avatar
so whats our options? keep stock pulleys?
