Porting out Throttle body, have question?
Old Feb 13, 2004 | 10:50 PM
Ceasars Chariot's Avatar
Old Maxima Legend
I just started looking into this (friends suggestion) and wanted to see what the anyone thought.
I believe our stock throttle body is 60mm and was told to bore or port it to 63mm or 64mm.
Can you guys shed some light on the pros and cons of doing this mod.
Old Feb 13, 2004 | 10:56 PM
DAVE Sz's Avatar
Hooooooonda.....
Wouldn't this be pointless unless you also get a bigger butterfly plate? You can bore it out before the plate and after the plate but the airflow coming in would still be the same since the butterfly opening the same size. Am I right? Or would the butterfly plate not even matter since you can change the idle with the IACV screw? Sorry to write all this Ceasar but I was planning on doing the same thing. I don't see any cons to this anyway, only maybe if you made the whole thing bigger and the air would go around the plate and the IACV couldn't correct it.
Old Feb 13, 2004 | 11:06 PM
Old Maxima Legend
any post is a good one ! would like to figure this one out !
Old Feb 13, 2004 | 11:09 PM
DAVE Sz's Avatar
Hooooooonda.....
Don't mean to be rude but if anyone KNOWS where to get butterfly plates please post a link or something. Need one for my intake.
Old Feb 13, 2004 | 11:13 PM
I30tMikeD's Avatar
If you really want a larger TBj ust go with the pathfinder throttle body. You will get 10 extra mm instead of 2 or 3.
Old Feb 14, 2004 | 12:06 AM
DAVE Sz's Avatar
Hooooooonda.....
He'll need to make his own mounting bracket for that. New hoses and I think even new throttle cables. I don't think the dude that did this made any templates or anything. The PF TB is huge but costs A LOT more.
Old Feb 14, 2004 | 12:39 AM
MaxiSpeed97's Avatar
you may also have a tough time installing the Pathfinder TB because its hard to match the voltage for wiring of TPS
Old Feb 14, 2004 | 01:03 AM
krismax's Avatar
Father of the 00 VI
My TPS is fine my throttle cable is still stock as my vacumm hoses. Just need adapter plate and bottom plate if 95-96 and 97-99 just need main adapter plate . My plate is 3/8 inch thick aluminum make it any thicker and you will have issues.
I sold them to mike recently if he doesnt mind maybe he could post pics to help you guys out.
Another thing is if you guys ever have plans to put a 2000 manifold on the pathfinder TB is useless ,because you cant port match the 2000 manifold.I will have my adapter block turned out about 65 mm and use the venturi effect. Kind of like a funnel after the TB.
Old Feb 14, 2004 | 05:38 AM
I30tMikeD's Avatar
it's not really an expensive mod at all. It's gonna cost me less than $200 for everything. having a shop do porting is expensive.
Old Feb 14, 2004 | 06:48 AM
96sleeper's Avatar
i have a stock throttle body laying around that has been mildly ported, polished, and the lower butterfly rod has be trimmed off. Send me a PM if you want it cheap Ceasar. I don't think it will give gains like a Pathfinder TB, but its better than stock.
Old Feb 14, 2004 | 07:07 AM
BEJAY1's Avatar
Conecarver
I tried a 64mm one last year and didn't show much dyno gain so I went back to stock.
http://forums.maxima.org/showthread....light=throttle
IMO the 70mm PF solution is a much better investment. I just can't do it to my ride
Old Feb 14, 2004 | 07:39 AM
Old Maxima Legend
bejay why would you go back to stock though ? what kind of gain 1-5 hp ?
Old Feb 14, 2004 | 08:03 AM
maximabebe's Avatar
out of curiosity, what years pathfinder throttle bodies would be "compatible" for a 95 max SE?
Old Feb 14, 2004 | 08:06 AM
I30tMikeD's Avatar
only the 2001 3.5 is 70mm and can be adapted to fit.
Old Feb 14, 2004 | 08:47 AM
maximabebe's Avatar
thanks mike
Old Feb 14, 2004 | 09:06 AM
Tatanko's Avatar
Bacon Lover
So if you have to have an adapter plate...hmmm...I assume no one makes one that'd be useable for a Maxima. It'd be nice of someone to make a template for others to use
Old Feb 14, 2004 | 09:31 AM
ben99sel's Avatar
I think your gains would be minimal...3-5 horsepower if you are lucky... but at the sametime, that is 3-5 horsepower!
Old Feb 15, 2004 | 08:02 AM
BEJAY1's Avatar
Conecarver
Definate throttle response gains but no valid dyno proof. Last dyno I got was questionable STD not SAE. I spent lots of time checking the conversion factors but still looked like a net of -3.5hp and +3.2tq using 64mmTB, EHd intakes, and a new Ypipe flex. I basically dismissed the pulls and just keep moddin.
Old Feb 15, 2004 | 08:07 AM
I30tMikeD's Avatar
LOL that's the spirit!
Old Feb 15, 2004 | 08:15 AM
C MAX's Avatar
when i had mine done .. it was port and polished.. i think it just reduces the drag, so as you modd more it will start to show some benefits... especially when you go FI
Old Feb 15, 2004 | 08:39 AM
MaximaEvolution's Avatar
````STD?````
Old Feb 15, 2004 | 09:42 AM
Old Maxima Legend
should this be ? +3.5hp and +3.2tq
if not thats a crazy gain a small decrease in hp and a small increase in torque
Old Feb 15, 2004 | 09:55 AM
nismology's Avatar
Well the gains from a pathfinder TB must be awesome if Krismax is making almost 200FWHP without a MEVI!!!
Old Feb 15, 2004 | 10:05 AM
RastaManMax's Avatar
Big D you are right in saying this.
Have any of you ever thought of the 90-92 pre-trac control Q45 TB's? It's a whopping 85mm. If somebody could get this monster to fit and fab up a kit for cheap i'd definately be in for one of those.
LEMAR
Old Feb 15, 2004 | 11:29 AM
96sleeper's Avatar
He dynoed on a dynapack, not a dynojet. They always read high, so you can't compare directly.
Old Feb 15, 2004 | 11:30 AM
ABK's Avatar
ABK
hey krismax since you did this before would you be interested in making those plates again, and we could possibly buy it off you?
Old Feb 15, 2004 | 11:46 AM
nismology's Avatar
Even if the numbers are higher than they should be, the fact that he has more HP than TQ says alot because that is usually unheard of without a MEVI.
Old Feb 15, 2004 | 03:33 PM
Dave B's Avatar
Not DAVEB the parts guy
I don't think TBs will do much for our NA 4th gens. Most other NA cars on the market are lucky to see 2-3 peak hp with a larger TB. I'm talking about Hondas, GMs, other Nissans, Fords, BMWs, etc. The 60mm TB on the 4th gen is the same size as the one used on the 4.6 SOHC Mustang V8. I think 60mm is probably plenty. The reason guys feel better throttle response with the 70mm TBs is because more air is coming introduced at every throttle input compared to the 60mm TB. Just because the TB is bigger doesn't mean the engine can use it. Bigger is not always better. If that was the case we'd all be running 80mm TBs and 4" bus exhausts.
Dave
Old Feb 15, 2004 | 04:00 PM
Scruit's Avatar
U wanna try me young boy?
You can make a throttle plate out of a piece of copper sheet.
You gonna port the MAF also? Otherwise it's not worth. If you do then good luck recalibrating the MAF sensor signal to the ECU. Maybe work with Jim Wolfe?
Old Feb 15, 2004 | 04:15 PM
krismax's Avatar
Father of the 00 VI
The day i dynoed ,i dynoed in the middle of 15 350 z's. Some stock 3 supercharged one guy paul from avalon racing was putting down almost exactly what he did on a dynojet a few days before. One stock one put out 228 rwhp , most in the mid 230's .
I guess then those #'s are to high to then.
Old Feb 15, 2004 | 04:17 PM
krismax's Avatar
Father of the 00 VI
The maf is already 70 mm or more.
When a b-16 honda goes to the type -r TB ,there is about a gain of 7 fwhp
Old Feb 15, 2004 | 04:21 PM
maxspeed96CT's Avatar
The original VQ...
is there a write up on the PF throttle body?
Old Feb 25, 2004 | 05:04 PM
Old Maxima Legend
any more thoughts or views ?
Old Feb 25, 2004 | 07:28 PM
I30tMikeD's Avatar
yhea, it impossible to find a cheap used PF TB
Old Feb 25, 2004 | 07:40 PM
MrGone's Avatar
Just port your stocker. Cheap and effective. Yes there is the arguement on if the butterfly plate diameter doesnt change then it doesn't do any good, but my experience has been otherwise.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
Sep 15, 2015 06:47 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
