PCV Valve Location/ Temperature Switch
Old Feb 17, 2004 | 03:46 PM
clozoya's Avatar
Hi everyone......nice forum! Anybody knows the location of the PCV Valve on a 93' VE30DE, automatic? Also, the temperature selector switch only goes from cold to the middle and that's it. Does not go to the hot side. Any ideas?? Any help is appreciated....
Old Feb 17, 2004 | 05:12 PM
Damonb's Avatar
Uhh dude, if your temp goes to the hot side, you have major issues, it should never get above the middle point unless it is REALY hot out and only a tad bit over the middle in that case.
The PCV is located on the valve cover, there is a large vaccum hose going to it.
Damon
Old Feb 17, 2004 | 07:04 PM
internetautomar's Avatar
mod or sell?
Damon
He's refering to the climate control lever I believe
Old Feb 18, 2004 | 05:19 AM
Damonb's Avatar
ahhh, now that makes more sense... it jammed?
Old Feb 18, 2004 | 06:49 AM
mod or sell?
Probably, nothing too unusual from what I've read on here.
I've currently managed to get mine over all the way and won't push it back till we get into the 70s up here
Old Feb 18, 2004 | 07:44 AM
Mizeree_X's Avatar
Getting back to his roots
The PCV valve is located behind the intake manifold, close to the firewall. Find the NISSAN etched into the upper part of the manifold, and look behind it it. About 8" down, there will be a rubber hose coming out of the manifold at a 45 degree angle. It is connected to the PCV valve. There is another valve for the brake booster that looks similar, so make sure you have the correct one. You need a deep 19mm socket I think to remove it. Good luck.
Old Feb 18, 2004 | 10:24 AM
clozoya's Avatar
Yes, I'm referring to the control climate lever......It's jammed.......
As for the PCV valve, I think I know which one it is, it's on the left side (looking from the front) on the very back......I had not noticed it before.....thanks
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
tseng1023
Oct 15, 2015 08:30 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
