Can UR Car drive straight?
I have 2 4th gens (96 and 99). they both pull left and suffer from a slight vibration. It'd been present when it was stock, lowered, w/ stock wheels and 19's, after balancing and an allignment. It just does it no matter what I do in both cars. Whats the problem?
Originally Posted by felix822
i'm gonna go back and complain. make them try it again.
Originally Posted by CystumMax
I don't think that would work, I have heard from like 2 people saying the same thing after they droped their car, it pulls to the right. but it is worth the try.
just got my aligment done after some work on my rack and pinion. And now my car drives pretty straight going 75mph. It will go staright for few minutes, then it starts to pull really slowly
http://home.earthlink.net/~maxfaq/suspension.htm#pull
My car pulls too. I've had 3 alignments in the past 2 yrs, and nothing works. I'm going to try this when I put new bushings on my front sway bar.
I took my 98 to a specialty guy, and he told me that lowered Maximas (and older 300z's) he has found to have a problem with pulling to the right. He had no explaination why, but the 3 people I took it too and told me it was aligned correctly sure back his claim up. the only possiblity I havent counted out is radial pull (which is unlikely, but possible, considering the car did not pull before i got higher performance tires) -my 2 cent
if ur car pulls to the right on a normal road than its normal, because thats how roads are made so that the water from the rain goes to the sides of the road and doesnt just collect in the middle. So basicall most of the roads are made like that, well at a slight angle, to allow the water to always go to the right no matter which way ur driving on the street and so hence ur car pulls to the right as wee.
and if it pools to the left u might want to check out ur motormounts as well.
If I drive smack bang in the middle of the road, it'll go straight, otherwise it'll pull to the left (LHD roads
). Just recently had it re-aligned after it started suffering from some major shakes, took the garage two days, but they re-aligned it perfectly (as well as checking to make sure it wasn't anything major causing it)
Mine pulls left like a ****. Our springs rotate, I can spin them back into place and it will drive straight. But when im cutting the wheel sharp in a parking lot they will start to spin, and pop and my alignment goes w/ it. Anyone experience the same thing
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
