O2 sensor and Knock
O2 sensor and Knock
Ok, I checked my ECU codes a couple of days ago and it said I had a bad knock sensor and a bad O2 sensor. I reset the ECU and then drove for 3 days and then checked the ECU codes again and it said I didn't have anything wrong. I don't really know what to do. Should I maybe take it to the dealer to get the sensors checked out? I would check the sensors myself but I am incredibly dumb with cars. I am just afraid that I am putting money into performance parts, when my Max is not even running very strong. Thank you.
Originally Posted by ABK
i think your O2 sensor is tripping the KS. Try replacing the O2 sensor you might also wait for response from other org memebers.
I think it's the O2 sensor from the front of the y-pipe
The first one from the front.
Originally Posted by Maxjm
Yeah that is what I figured too, but it is weird how it doesn't show up on the codes anymore when I check them. It says that it is the front left O2 sensor (I have 2 O2 sensors) so that would be the O2 sensor to the right when you open your hood right? The one that is closest to the front. Thank you for the reply.
Unplug the wire for the old sensor and take out the old sensor. Put in the new sensor and plug it in and you're done
Originally Posted by JaTaN
Don't bother with the dealer. If it was the front left O2 sensor, then it is the one near the radiator. Just replace it and you'll be fine. Buy the OEM type one from http://www.oxygensensors.com and get an O2 socket and you're set.
Originally Posted by I30tMikeD
Just drive it till the code comes back....your not really hurting anything. If it comes back then replace the o2 sensor.
Finally, do you think going to the track would be a good test also? I mean I have never gone or anything, it could be a good base I suppose.
After a week and a half of driving around, I decided to check my ECU again and it did not give me a knock sensor or O2 sensor code. Should I just not worry about it? It really is just a bit odd that it threw those codes the first time I checked.
Originally Posted by s3roush628
Not to be a n00b, but how did you check ur ECU? I wanna make sure my O2 and knock sensors are ok b/c i get horrible gas mileage. thx guys
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
