Willl SL get 5 Speed Trans
Old Feb 23, 2004 | 05:10 AM
95Max's Avatar
I know that there have been some rummers about the 4 speed trans in the SL going to the 5 speed that is in the SE. Anyone have any info if this is really going to happen?
Old Feb 23, 2004 | 06:46 AM
VQ35DE's Avatar
This change has already been implemented at the plant, THIS IS A FACT.
Old Feb 23, 2004 | 07:48 AM
95Max's Avatar
For the 05 or will be avail if order the 04 SL?
Old Feb 23, 2004 | 07:51 AM
VQ35DE's Avatar
The 2004's.
Old Feb 23, 2004 | 08:57 AM
95Max's Avatar
The 2004's.
Called 800-nissan1 and they said that the 04 SL is avail only with the 4speed trans. Where did you hear that the SL is getting the 5 speed?
Old Feb 23, 2004 | 10:04 AM
VQ35DE's Avatar
FROM NISSAN SITE, those 1-800 people don't know crap!
"All 2004 Maxima's come equipped with a standard 5-speed electronically controlled automatic transmission with manual shift mode and gated shifter for better transmission control. New to the 2004 Maxima is Vehicle Dynamic Control (VDC) with Traction Control System (TCS), which is optional on all A/T models."
Engine and Driveline
3.5-liter DOHC 24-valve V6 producing 265 horsepower and 255 lb-ft torque
Engine features include electronic throttle, silent timing chain, microfinished camshaft and crankshaft surfaces, molybdenum coated pistons, resin intake collector, digital knock control system, cross flow coolant pattern and high capacity muffler
Platinum-tipped spark plugs with 100,000-mile maintenance intervals
6-speed close ratio manual transmission optional on 3.5 SE models
Standard gated 5-speed electronically controlled automatic transmission with manual shift mode
Vehicle Dynamic Control (VDC) with Traction Control System (TCS) available on most A/T models
Available helical limited-slip differential (3.5 SE manual)
Old Feb 23, 2004 | 10:06 AM
VQ35DE's Avatar
Models and Manufacturing
Offered in two well-equipped V6 models: 3.5 SE and 3.5 SL
New mid-year packaging (effective 2/6/04)
Exterior and interior designed at Nissan Technical Center (NTC) in Atsugi, Japan
Assembled for the first time in the United States at the award-winning Nissan North America Manufacturing Smyrna & Decherd Tennessee Plant
Transmission and Drive System
3.5SE 3.5SL
Drive configuration
Front engine / front-wheel drive
Transmission Type
6-speed manual O -
5-speed automatic with manual shift mode & gated shifter S S
Transmission Control - Automatic Electronic
Vehicle Dynamic Control (VDC) with Traction Control System (TCS) (A/T only) O
Gear ratio
6 M/T 5 A/T
1st 3.153 4.657
2nd 1.944 3.032
3rd 1.392 1.982
4th 1.055 1.341
5th 0.809 1.018
6th 0.630 -
Reverse 3.002 5.114
Final drive ratio
4.133 2.440
Helical Limited-Slip differential (M/T only)
O
Old Feb 23, 2004 | 10:08 AM
VQ35DE's Avatar
The Bottom Line Is There Ain't No 4-speed No More, Only 5-speeds.
Old Feb 23, 2004 | 10:11 AM
VQ35DE's Avatar
3.5SE 3.5SL
Drive configuration
Transmission Type
6-speed manual O -
Old Feb 23, 2004 | 10:18 AM
95Max's Avatar
Is this from nissanusa.com? It show the SE w/ the 5 and SL w/ the 4 speed trans
Old Feb 23, 2004 | 10:24 AM
VQ35DE's Avatar
http://www.infinitinews.com
Go to products and work your way to 2004 Maxima.
These
changes are also in the most recent ( 12-03) dated, Maxima brochures.
Good Luck!
Old Feb 23, 2004 | 10:26 AM
95Max's Avatar
These
Good Luck!
You da man
Old Feb 23, 2004 | 10:38 AM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
excellent find!
http://www.nissannews.com/nissan/200...ma/specs.shtml
The latest spec sheet only lists the 5A/T ratios and the 4A/T is definitely going away.
Old Feb 23, 2004 | 10:45 AM
VQ35DE's Avatar
As of 2-6-04 the OPTION PACKAGES have changed also. My car was built on 02-06-04.
Old Feb 23, 2004 | 11:03 AM
95Max's Avatar
What are the changes?
Old Feb 23, 2004 | 11:08 AM
VQ35DE's Avatar
Click on pricing for the Max at the site I gave you, look at THE OPTION PACKAGES and compare to the first part of the model year.
Old Feb 23, 2004 | 09:52 PM
annimax's Avatar
I am extremely pleased with my 2k4 SL however the added performance of the 5-speed would have been nice to have if I had been more patient. The owners of the new 5-speed SL are sure to enjoy it.
Old Feb 24, 2004 | 12:16 PM
MaxPilot's Avatar
This is really going to kill re-sale value of the 4speed SL's! I think Nissan owes us a transmission upgrade!
Old Feb 24, 2004 | 01:00 PM
ga2000's Avatar
hmmm the sl might be evan faster than the se, since its gonna have lighter wheels. 17 compared to 18s on the se.. the 5spd was the advantage over the sl. atleast im pretty sure it was..
Old Feb 24, 2004 | 10:27 PM
annimax's Avatar
I wish it was that easy. You win some, you lose some.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
ef9
Oct 4, 2015 08:43 AM
