Willl SL get 5 Speed Trans
Originally Posted by 95Max
I know that there have been some rummers about the 4 speed trans in the SL going to the 5 speed that is in the SE. Anyone have any info if this is really going to happen?
Called 800-nissan1 and they said that the 04 SL is avail only with the 4speed trans. Where did you hear that the SL is getting the 5 speed?
"All 2004 Maxima's come equipped with a standard 5-speed electronically controlled automatic transmission with manual shift mode and gated shifter for better transmission control. New to the 2004 Maxima is Vehicle Dynamic Control (VDC) with Traction Control System (TCS), which is optional on all A/T models."
Engine and Driveline
3.5-liter DOHC 24-valve V6 producing 265 horsepower and 255 lb-ft torque
Engine features include electronic throttle, silent timing chain, microfinished camshaft and crankshaft surfaces, molybdenum coated pistons, resin intake collector, digital knock control system, cross flow coolant pattern and high capacity muffler
Platinum-tipped spark plugs with 100,000-mile maintenance intervals
6-speed close ratio manual transmission optional on 3.5 SE models
Standard gated 5-speed electronically controlled automatic transmission with manual shift mode
Vehicle Dynamic Control (VDC) with Traction Control System (TCS) available on most A/T models
Available helical limited-slip differential (3.5 SE manual)
Models and Manufacturing
Offered in two well-equipped V6 models: 3.5 SE and 3.5 SL
New mid-year packaging (effective 2/6/04)
Exterior and interior designed at Nissan Technical Center (NTC) in Atsugi, Japan
Assembled for the first time in the United States at the award-winning Nissan North America Manufacturing Smyrna & Decherd Tennessee Plant
Transmission and Drive System
3.5SE 3.5SL
Drive configuration
Front engine / front-wheel drive
Transmission Type
6-speed manual O -
5-speed automatic with manual shift mode & gated shifter S S
Transmission Control - Automatic Electronic
Vehicle Dynamic Control (VDC) with Traction Control System (TCS) (A/T only) O
Gear ratio
6 M/T 5 A/T
1st 3.153 4.657
2nd 1.944 3.032
3rd 1.392 1.982
4th 1.055 1.341
5th 0.809 1.018
6th 0.630 -
Reverse 3.002 5.114
Final drive ratio
4.133 2.440
Helical Limited-Slip differential (M/T only)
O
3.5SE 3.5SL
Drive configuration
Transmission Type
6-speed manual O -
Gear ratio
6 M/T 5 A/T
1st 3.153 4.657
2nd 1.944 3.032
3rd 1.392 1.982
4th 1.055 1.341
5th 0.809 1.018
6th 0.630 -
Reverse 3.002 5.114
Final drive ratio
4.133 2.440
O
3.5SE 3.5SL
Drive configuration
Transmission Type
6-speed manual O -
3.5SE 3.5SL
Drive configuration
Transmission Type
6-speed manual O -
Originally Posted by VQ35DE
FROM NISSAN SITE, those 1-800 people don't know crap!
http://www.infinitinews.com
Go to products and work your way to 2004 Maxima.
These
changes are also in the most recent ( 12-03) dated, Maxima brochures.
Good Luck!
These
Good Luck!
These
Good Luck!
These
Good Luck!
You da man
excellent find!
http://www.nissannews.com/nissan/200...ma/specs.shtml
The latest spec sheet only lists the 5A/T ratios and the 4A/T is definitely going away.
The Bottom Line Is There Ain't No 4-speed No More, Only 5-speeds.
knight_yyz
11-01-2015 01:34 PM
